  1. yellow75
    Tillamook Oregon
    Got a new set of Hooker 6901 ceramic coated headers to put on the Stallion, while I was putting the car in the garage to install them all of a sudden the steering got a little harder when I got it parked I noticed fluid on the ground looked under the car and it was coming from steering cylinder so I guess I will get to fix that now.
    While I am under the car working I might as well pull the tranny and get it rebuilt to get rid of 2nd to 3rd flair and install motor plate that previous owner failed to put back on after motor was rebuilt .
  2. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    got this monstrosity 302/c4
    Krazy Comet, RMiller and BBMS18 like this.
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Not much to speak of but did look at my exhaust manifolds that I was planning to sell and saw the passenger side is cracked. Good thing I wasn't going to use them!
  4. 71gold
    did you get this straightened out?
  5. Earl Branham
    Lugoff, SC
    I got the parts put in, but my sister has had to have surgery again, and had to wait to ring the wiring out and start it up. Weather is cooling off on Sat. so that will be when I get out there and hopefully button this thing up. Been too long since I have driven it. How's the floors going?
  6. stumanchu
    stumanchu Stuart
    Portland, OR
    Finished my 3g alternator upgrade yesterday. Had to swap my improvised 351 alternator bracket for one off of a 72 302 Ranchero. I think I have the correct one now. NAPA was a total belt failure, but autozone hooked me up with a slightly larger belt as their part number system seems to be based on size. Vac advance was shot too, and replaced with one for a 66 289 Mustang (NAPA) that had the allen wrench adjustment. Seems to add 15 degrees advance at 14 in. vac. Will test drive today.
  7. William623
    Orlando
    1973 ford maverick grabber
    Went to a local car show/swap meet and found some pretty good parts for a fantastic price F5635555-6F5C-428D-AE6A-7C79FB6C02D6.jpeg
    Maverick_Ian90 and BBMS18 like this.
  8. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    I’m s that the clutch fan you’ve been looking for?
  9. William623
    Orlando
    Wasn’t looking for this once exactly but I found it today and worked out a deal with the guy. It should work well!
    BBMS18 likes this.
  10. stumanchu
    stumanchu Stuart
    Portland, OR
    Finally got a test drive in. Car runs a little smoother, and 2-3 shift got better....or is just my imagination? Seems to not slip as much with a vac pot that holds vacuum. Now I gotta read up to try and understand this.
    yellow75 and BBMS18 like this.
  11. RMiller
    Kennewick, WA
    Cleaned up the garage then put the engine and the C4 in the car. Next step is put together the engine mount kit from Rough Stuff and get the Tremec situated so I can make a cross member and put a hole in the floor. Also put the new bell housing on the transmission so I can bolt on the Rosehill slave cylinder and verify all is well there.
  12. ike72com
    ike72com Member
    Charleston SC
    I pushed mine in garage today before rain and cooler weather arrives.
  13. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    2019-10-14 15.57.44.jpg 2019-10-14 11.04.48.jpg Spend 8 hours getting intimate with two grinders. 2019-10-14 15.57.44.jpg 2019-10-14 11.04.48.jpg
  14. RMiller
    Kennewick, WA
    That's looking good! It's a ton of work especially when laying on your back. I still have a ways to go on mine but, I don't have to do it laying down thanks to some 2x6's that allow me to tip the car on it's side.
  15. ike72com
    ike72com Member
    Charleston SC
    Snake!!! My hat goes off to you! You made underneath your car look like chrome. You did a great job man!
