  1. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    You gota love the washing machine size box for the shipping of a air filter!(n)
    mojo and Maverick_Ian90 like this.
  2. 71gold
    still cleaning up some wiring. moved my E-waterpump relay, now the wires can be almost a ft. shorter. going to up size the power wire to the relay to match the wire size from the pump. things I should have done when I first installed it. I'm a...run a wire and see if it's wired right kinda person... then if it works I come back sometimes months/years later and wire it correctly...yes I'm one of these Guys that read the instructions only if it don't work the first time I try it...LOL
    mavgrab302 likes this.
  3. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  4. mavgrab302
    My 6901 headers fit, but I couldn't turn left very sharp because the pitman arm hit.
  5. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Thanks!! Then I guess I dont have to fix the left turn signal, LOL
    71gold and mavgrab302 like this.
  6. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    cleaned the engine bay
  7. BBMS18
    BBMS18 Member
    75 Comet
    Nothing :(
    But I did help Blink71 install a Unisteer rack & pinion kit on his Comet GT, we’re now figuring out what we need to connect the column to the rack and searching for a AN fitting for the pump.
    (y)
    489D4C91-48F3-4CC4-A59A-4D1D0BD733D2.jpeg 9D167E2B-609D-4D1C-A1E1-36E677B28614.jpeg ABAA8CC8-4B74-4A30-87E6-16117D35B9FF.jpeg
  8. William623
    Orlando
    1973 ford maverick grabber
    Tore apart the dash and found this nice surprise after I pulled off the factory insulation. Never seen one rust here before. The bottom is absolutely perfect. 136F0BA9-824B-44CA-BC9B-C673537487CC.jpeg
  9. maverick600
    maverick600 Member
    San Angelo, Texas
    Found some used 14's so I jacked up the car to take the wheels off, realized that I have 2 different types of rims. Both seems to be magnum 500 style, both are steel rims but 2 of the 4 have chrome on the "spoke" and the other 2 do not.
    Also recieved a package from a member on here and found out that all gas caps do not interchange AND neither do the sending units. I now have a NOS gas cap and NOS sending unit that I can not use. Not to the fault of the member, I should have asked more questions and did more research.
  10. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    Got some spark plugs from Benevolent Overlord Bezos today. Tune up materials almost acquired.
  11. William623
    Orlando
    Take a picture of your new gas cap and your fuel filler neck. If you like the gas cap just get a new fuel filler, much easier to do than finding a nice gas cap.
    Krazy Comet, 71gold and BBMS18 like this.
  12. maverick600
    maverick600 Member
    San Angelo, Texas
    My understanding is that since mine is a 70...all the other necks are different. I will snap a pic for the thread.
  13. maverick600
    maverick600 Member
    San Angelo, Texas
    The last 2 pictures are a comparison of the new cap and the old one that came with the car.
  14. Krazy Comet
    Dismal Swamp
    Painted "Magnums" were common in the Granada era, were a popular option & possibly std on some models.
  15. William623
    Orlando
    Ah you have a California car... it takes a special gas cap to fit that unfortunately. Extremely hard to find. You can swap your neck to a regular 70 neck if you put in the standard 70 tank I believe.
