  1. ike72com
    ike72com Member
    Charleston SC
    Does yours look like mine from front? Please share your part #. Thank you.
  2. EMcClintonMav
    EMcClintonMav Member
    Arlington
    Today I had my carb rebuilt and replaced the valve cover gasket. The 200 i6 runs great! 90796EA2-.jpg
    Russell, Ace5909, ike72com and 2 others like this.
  3. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    Actually, I did both sides:
    Passenger: C7AZ-17696-CS
    Scott Drake Exterior Mirror Standard Satin With Convex Glass Passenger Side 1967-1973
    Driver: C7AZ-17696-AS
    Scott Drake Exterior Mirror Standard Satin 1967-1973
    The mirror glass and flag are almost identical the stock Maverick/Comet mirrors, but the Scott Drake foot is longer than our stock mirrors. I had to drill a new hole on the driver side for the rear screw. They are also satin finish as opposed to chrome, but they look like they belong there. Especially on my car, with its low-gloss faded paint.
    Image shows install driver-side mirror with stock mirror above for comparison.
    Ace5909 and ike72com like this.
  4. ike72com
    ike72com Member
    Charleston SC
    Thank you CA189HJN. Just what i wanted to knw.
  5. 71gold
    hooked up the shift and throttle cables. now to to snap the cable to the gas pedal...test drive.
    :drive:...:chirp:
  6. Ace5909
    Ace5909 Member
    Saint Amant, LA
    Just a truck for now
    Installed 3.80 gears in the rear on my comet gt. 351W with AOD, cruised around with the gps to determine how bad off my speedo is now. Perfect gear combo for me. Showed 55mph at slightly over 1800 rpm, 72mph at a tick over 2300. Great power band now and stupid quick acceleration compared to the 2.79s that came out.
    CA189HJN, BBMS18, Krazy Comet and 2 others like this.
  7. mojo
    Sounds like a great combination. What is the advantage/purpose heat wrap on the tail pipes?
  8. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Finally got around to doing this. I always liked the 70 - 73 Mustang twist locks. Still a little tweaking to do but the hard part is over.
  9. Craig Selvey
    Do they latch to the radiator support?
  10. William623
    Orlando
    1973 ford maverick grabber
    I’m guess the exhaust is too close to the gas tank and causing it to heat up. I had the same issue on my 73 and did the same exact thing.
  11. jasonwthompson
    Carrollton TX
    I used the factory latch supports for a 71 - 73 Mustang that attach to the radiator support at the hood bumpers, although they must be flipped around towards the engine.
  12. Ace5909
    Ace5909 Member
    Saint Amant, LA
    Just a little too close to the gas tank
  13. Jmdelto
    Jmdelto Member
    Memphis, TN
    1972 Ford Maverick Grabber
    Changed out my supercharger belt to a new Gates HD, quick and painless.
    Ace5909 likes this.
  14. RaceReadyMav
    RaceReadyMav Member
    Newburgh Indiana
    73 Maverick
    Got my tach conversion done
    plynch, M7A7V, CA189HJN and 5 others like this.
  15. Hotrock
    Munroe Falls, Ohio
    I needed something more to do while I stay confined at home due to CoVid19. Changed the jets on a Speed Demon 650 I had and re-installed it in place of the 750 Speed Demon that was on my Comet. I still have some fine tuning to perform.
