  1. William623
    Orlando
    1973 ford maverick grabber
  2. 71gold
    got Patches ready for a road test tomorrow. everything is on except the breather, it needs a little tweeking.
    ran it on the lift to check transmission shift points, took it to...101MPH...everything is a go...
    :drive:...:chirp:
  3. ike72com
    ike72com Member
    Charleston SC
    The Good
    I got master cylinder done today. Wesley at Napa auto in mt pleasant s.c helped me out greatly today. Big thumbs up!!! All new fitting and lines. Sent me out door with exactly what i needed. Got home flared line, bend and installed. Done!!!:rednose:
    The bad.
    Went to take off differential drain plug.
    Rusted on good. Ended up losing battle and stripped 3/8 drive hole.:stirthepot:
  4. William623
    Orlando
    Got the fan all wired up. Man does that think work well! Simplified my wiring harness and got to enjoy the car for a. It.
    Earl Branham and ike72com like this.
  5. 71gold
    got it back on the road, test drove it today and it did great...:drive:...:chirp:
    CA189HJN, Earl Branham and mojo like this.
  6. mojo
    I assume I have a 3 core. Champion CC339 series -- 2 3/4 " thick core -- Wondering if you a different series? I wound up fabbing a shroud. I couldn't get the fan centered over WP the pulley w/o shroud.
  7. mn67
    mn67 Member
    Great white north
    I finally buttoned up my seats, color sanded and polished the doors and fenders. Starting on the rest of the body as soon as the cold snap ends.
  8. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    CONGRATULATIONS !!
    Know the feeling ...
    Cometized
    Chip
    71gold likes this.
  9. Earl Branham
    Lugoff, SC
    Took mine out for a ride yesterday, just to keep things moving. Car ran great once it is warmed up, but fast idle refuses to work, and now that its warming up, less of a concern.
    71gold likes this.
  10. 71gold
    replaced the A/C drier and charged up the system. ready for a 100 mile ride tomorrow (per instructions) for the self learning of the EFI...:bouncy:
    CA189HJN, stumanchu and Earl Branham like this.
  11. stumanchu
    stumanchu Stuart
    Portland, OR
    Over the last 3 days, I dropped my c4 valve body and put in a transgo SK C5 shift kit, installed a H servo, new shift shaft seals, and a green stripe push in modulator. It was my first time with a valve body, and putting it back in was exhausting. That thing felt like it weighed 50 pounds on the final try. I learned this....kickdown and shift cable MUST be disconnected, kickdown lever MUST be in exactly the right spot, and the shift valve is actually visible when the detent spring is off. Thankfully, I got it all right BEFORE pan installation. Road test today went well I think....all shifts are quick and firm when manual shift or accelerate hard in D. 2-3 shift in part throttle seems slow but doesnt slip? Doesnt leak. I think I am ready for that junkyard motor now.
    CA189HJN likes this.
  12. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    That looks great!
    mn67 likes this.
  13. WiscoMav
    WiscoMav Member
    Greenfield, Wisconsin
    Finished Digitails install. Blacked out taillight panel, new gaskets for taillight lenses, and all wired up. Need to put quarter panel extensions and bumper back on.
    mojo and Shorty like this.
  14. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    Took out the radiator and carb so I can get ready to pull the engine over the weekend. Transmission bolts and engine mounts to be removed soon.
  15. ike72com
    ike72com Member
    Charleston SC
    Why/what motor are you pulling? Rebuild time?
