  1. ike72com
    ike72com Member
    Charleston SC
    I back 72 out of garage and drove around in yard.
    Engine good, trans good in all gears, brakes good, all lights good.
    No plate or insurance yet so no road test. I,m calling Mr. Grundy in morning:D.
    CA189HJN, mvw66gt and 71gold like this.
  2. 71gold
    they have been working on a road about 20 miles from here. the road has been closed for about 6 months. so it opened last Friday, so I road down to see it today in the Mav...:drive:...:chirp:...:outtahere:
  3. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    Yes. Need to change spark plugs and I have a suspicion that one of the head gaskets are damaged. Plus, I would like to clean it up a little.
    ike72com likes this.
  4. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Installed NEW electric motors in the Power Windows and they really " Zip" now .. they were slower to operate than
    I liked so we souped them up with NEW motors and it made all the difference. We set it up where the stock window
    crank handle is the " Switch" .. Looks stock but is much improved . I'm doing my Daughters 72 Maverick next f0r her Christmas Present ( belated ) . Not a big deal if anyone is interested .
    Cometized
    Chip
    x72COMETx and William623 like this.
  5. x72COMETx
    x72COMETx Member
    Vallejo CA
    Is their any chance you would do a write up on the process, definitely interested in doing this on my own ride
  6. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
  7. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    The Write-Up was pretty much covered by the other Mr.Pittman when you click on his address he'll explain step by step . The only difference is , I didn't use the console or separate switches. I ordered some switches from CA and then modified them to fit in my doors and connected them to the actual window cranks . Looks stock but worked out really well . We've done Three Cars so far and my Daughters 72 Maverick is next . I'll take pictures then and put them on my CAMEO website for all to see. I like the stock looking appearance and they work as well as a switch in the console or other location. I think it's more convenient and it doesn't clutter up anything . It always is a hit when I demonstrate them at a car show . Worth all the effort !
    Cometized
    Chip
    Hotrock, 71gold and mojo like this.
  8. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    I can't believe it but I'm finally attempting to install my new heater core. I've been running around with a by-passed heater core all this time. I had the heater core pressure tested a long time ago and I now have some time to put it in. I'm using Frank's instructions he wrote and posted to forum. I've removed the glove box (on my '73) and the front trim and now I'm at " Remove plastic floor vent from blower/motor assembly." I felt underneath the assembly and there seems to be two round push pins or something like that joining the two assemblies. I slid my iphone underneath the floor vent assembly and took a snap, selfie-style. The photo is looking upward. If anyone or Frank himself can give me some direction here, I would appreciate it. So how to you get the plastic floor vent removed? Thanks. Greg (aka Maverick Dude). PS. I also posted in the Technical section.
  9. BBMS18
    BBMS18 Member
    75 Comet
  10. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    Worked on wiring for the 5.0l. Have to re-pin the ECM since I'm using a slightly different computer from the standard Painless recommended one (using a '94-95 W4HO vs the '91-93 A9P). Got the battery relocated to the trunk. Waiting for a new ignition switch to come in the mail. The old one was having issues and that led to a lot of trouble shooting until I figured out that is what was causing my solenoid trigger and key-on wires to constantly change.
  11. 71gold
    went to Summit today...it was interesting to say the least.
    no one was let inside...I had to order and pay for my part on the phone while sitting in the parking lot. only took about 15 minutes to get my part.
    thanks Summit for looking out for my well being...:Handshake:
  12. 71gold
    I had to mod my old fuel pump hanger to install my new fuel pump.
    I disassembled the old pump and put the new one inside it.
  13. mojo
    Old pump -- went south?
  14. 71gold
    didn't pump enough GPH for my new EFI. needed 57 GPH @ 58 PSI.
    mojo likes this.
  15. Maverick Dude
    The heater box was in good shape so I left it bolted to the firewall and removed the clips the pulled the front off. It all went well and I removed the heater core. It was corroded along the passenger side and bottom. I removed the metal flapper from inside the box and cleaned it up. The foam seals were all deteriorated. I have a seal kit from Melvin’s Ford Parts.
    71gold likes this.
