  1. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    I like your bracket better than the one I made.
  2. CA189HJN
    Scott Drake Exterior Mirror Standard Satin With Convex Glass Passenger Side Mustang 1967-1973
    C7AZ-17696-CS
    thegreenmonster likes this.
  3. maverick600
    maverick600 Member
    San Angelo, Texas
    Decided to clean up my tail lights and replace the gaskets. I bought the ones from Melvins...have to say that the foam is a little less spectacular than the original stuff and seems to be a little thinner as well. I'm hoping it will still seal.
    Also sanded down the housings and painted them.
    CA189HJN, mvw66gt and 71gold like this.
  4. 71gold
  5. stumanchu
    stumanchu Stuart
    Portland, OR
    I installed my header bolts. I forgot that I had to remove a broken exhaust bolt from my junkyard heads which in turn lead to ruination of enough threads that the header bolt couldnt start. So, cut the head off a longer bolt to make a stud, and used that. 2 hours to bolt up headers and then it started raining.
    CA189HJN and Maverick Dude like this.
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Got real close to being finished with welding the tunnel back in. Have a couple small spots left and knocking down the welds.
    Saw a shirt once that I should have, says "master welder" with welder crossed out followed by grinder.
    71gold, CA189HJN and stumanchu like this.
  7. stumanchu
    stumanchu Stuart
    Portland, OR
    After several hours worth of gas welding on my exhaust system, I turned a corner and my welds graduated from craggy mountains to rolling hills. I still will not weld anything that requires true structural integrity though.:drool:
    RMiller and CA189HJN like this.
  8. CA189HJN
    My partial front-end rebuild continues. Had trouble getting old shocks to play nicely with the new spring perches (angled differently). Hoping "good-enough-for-government-work" is good enough. MOOG strut-rod bushings look very nice. A different design than the original, which is different that what they'll hand you at your local Napa. The passenger-side original bushings had been installed backwards compared with the orientation of passenger side. These were the OEM bushings so this might have been done at the factory. Apparently, it doesn't make a huge difference.
  9. RMiller
    Kennewick, WA
    Mine is more of a fitment and metal quality issue. I think I have it trimmed just right and I missed or I think I am back to good solid metal and it's still a little thin. Sheet metal is just not my favorite thing to weld, thankfully I don't have a lot of practice with it!
  10. 71gold
    those look backwards...
  11. mojo
    They look right too me! If they're backwards mine been backwards for 8+ years and several thousand miles?:scratchchin:
    ike72com and Shorty like this.
  12. 71gold
    when I bought some new ones, the instructions showed to put them the other way...:huh:
    Mobiledreams likes this.
  13. mojo
    Sure u read them right?:huh:
  14. 71gold
    mine were paper instructions w/pictures...:yup:
    and I thought they went the other way.
  15. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    I keep hearing about the "improved" Moog bushings. What's different about them? I'm not questioning that they're better, I'd just like to know.
