  1. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    I don't know if they're better, but they're made of quality materials and "look" like they should work better than the one I took back to Napa. We shall see after I align it.
    Here's the instructions that came with mine.
  2. 71gold
    thanks...doesn't one of the cup washers look opposite of the other one? if so...why would it be?
    my set must have had the cups facing out on all four.
  3. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Has anyone tried the Global West high durometer bushings? https://www.globalwest.net/srb-5.html
    In principle at least looks like a good compromise between the stock, somewhat soft bushings and the very expensive aftermarket strut rods which use a ball joint or heim joint to replace the strut rod bushings.
  4. x72COMETx
    x72COMETx Member
    Vallejo CA
    Placed the fuel injection and ran the wiring into the car as I want to hide all those wires as much as possible, upon inspecting the wiring and figuring out where I’m going to make my wire taps I realized I really need to redo the wiring i did when I was 17, so I spent most of the day cutting out buttsplice connectors and traced all wires to make sure they are in good shape, once finished I made all the connections I needed for the fuel injection. Tomorrow I will hopefully have everything tucked up under the dash and tidy
    CA189HJN likes this.
  5. JL Mav
    JL Mav I almost made it to Lake Tahoe
    Douglas county NV
    72 Maverick, 68 Mustang, 61 F100 unibody
    Installed my new KYB shocks on the rear. Now I need to do the fronts but after installing a lot of aluminum on the engine I need to cut another half coil out of the front springs.
  6. Mobiledreams
    Mobiledreams Member Supporting Member
    Buffalo WV
    1976 Maverick
    Just went through this one. the paper instructions say front where the front isnt. It doesnt mean the front is where its printed on the paper but rather where the arrow is pointing to. Several members pointed out to me they looked backwards. They were. The rear washer is the one that doesnt cup the bushing.
  7. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    Took the not-four-years-old NPD reproduction copper-brass radiator out because it blew a top seam. Local shop brazed the entire top tank but screwed up the paint so I had to strip the top tank and repaint. Found that the VHT Ceramic SP139 "GM Satin Black" is a good match that has good adherence to copper-brass. 2020-05-09 08.11.38.jpg 2020-05-21 13.35.51.jpg
    Russell, mvw66gt, mojo and 1 other person like this.
  8. 71gold
    my regulator wasn't holding pressure when the key was shut off. it would just dump the pressure to 0 PSI. on fuel injection that makes for a hard quick restart.
    I pulled the reg. and when I broke the adjusting nut loose I heard a click. I'm thinking the valve was stuck. so I disabled and lubed it up real good and put it back on. it works great so far. even the vac assist is working like it should.
    May have saved $150 if this works.
    :drive:...:chirp:
    Russell likes this.
  9. mojo
    I'm thinking about painting my alum. rad. black -- where you get the VHT Ceramic SP139 paint?
  10. xpsnake
    xpsnake Bruce
    Hey Everett! I got it off of Amazon, though some of the parts houses can get it. Eastwood makes a great product for this, but it's on back order across the country until late June. The important thing is that it's thin, goes on thin, and doesn't kill the thermal efficiency.
  11. mojo
    Thanks Bruce! I'm going to check it out, Eastwood a 15 min. drive for me. Probably have to call see if store open to foot traffic.
  12. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Knocked off the last of the undercoating in the passenger wheel tub and front apron. All that is left is the drivers side apron. Started this mess four years ago, had a move between and a stretch where work was dragging me down that I made no progress but we're fullish steam ahead now!
  13. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    The LEDs from Amazon arrived today. Still waiting for the new temp panel control cable.
    96FF2AD9-13FE-4938-9702-2CC13646AFEE.jpeg 0940ED3F-2035-48B7-8EC3-88E70D61A558.jpeg 8E90B340-398C-4081-9590-1C6DC46DB2CC.jpeg
  14. JL Mav
    Douglas county NV
    Installed my new rear side marker lights. I ordered them from my local Torino/Fairlane supplier because they are the same part and were less than trying to buy them for a Maverick. Funny thing is when you look online another company has the same part number for the Fairlane and Maverick but it has a higher price on the Maverick part.
  15. maverick600
    maverick600 Member
    San Angelo, Texas
    Did it come with gaskets for the housings? I do not remember but I dont believe Melvins has the rear marker gaskets available.
