  1. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    First good drive of the car since back from the transmission shop. The rebuild C4 shifts significantly better than the sloppy job it did before. They put in a shift kit (we do it in all our C4s, they said). And it works well. Under light acceleration, it holds second up to about 30 mph. The third-second kickdown is nice and crisp. A couple of unidentified drivetrain noises went away. And ALL THE LEAKS STOPPED!! The builder, Pro Built Transmissions, of West Sacramento, used low viscosity fluid fluid, which seems to working fine (this was a full-tear-down and a dry fill, so no mixing with Type-F). They did the U-joints at the same time. Slowly, this car is coming together.
    Russell and ike72com like this.
  2. Krazy Comet
    I installed not one, not two, that's right three!!!!! Starter solenoids.
    Started out no crank, engine spun & started by jumping solenoid, yep croaked. Installed new, still won't crank. Yep, dead. Tested next one, operates fine(looks to be lightly used), installed, no crank. Tested again, tits up. Dayum!! By this time, only one on hand was the orig removed from Cobra approx three years ago(mainly cuz it was showing it's age, still electrically fine). Tested, checked out OK, installed. Cranks fine.
    Drove it 75 miles round trip to Smithfield, met friends & we ate outside... No issues. First time it's been out of neighborhood since last fall.
    stumanchu and ike72com like this.
  3. ike72com
    ike72com Member
    Charleston SC
    Sounds familiar Krazy Comet. Limme guest hummm? You got from allozone.
  4. Krazy Comet
    Uhh well no, I had all on hand, including the NOS installed on Cobra three years ago.
    The "looked new" was in a box of parts that came with a 428 Fairlane-500 bought probably 20 years ago.
    ike72com likes this.
  5. ike72com
    ike72com Member
    Charleston SC
    Okay fellas, i,ve been doing lots of reading and youtubing on cutting, buffing and polishing paint. Already started with my trunk.
    Just as painting this is new territory! Let me say!!!! How freakin nerve racking it is to seemingly wreck a decent paint job.
    Thought I screwed up royally!
    But after right tools, products, and being a little more agressive I'm seeing results.
    Let me say! I,ll never complain about any shop or business charging me fair labor for Body work, paint and detailing if I choose to go that route. Definitely a skillset and labor intensive. Those men earned what they make!
    Disagree or not
    CA189HJN and BBMS18 like this.
  6. stumanchu
    stumanchu Stuart
    Portland, OR
    I havent done it yet either. And like everything else, always a learning curve. You did well starting in the back. And yes, even though it would be money well spent, I am sure when I get there at some point I will be burning the paint off a few corners if I dont sand through first.
  7. ike72com
    ike72com Member
    Charleston SC
    I think i know what a burn is now!:sarcasticclap:
    stumanchu likes this.
  8. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    None of it is easy. I farm out very little work on my vehicles, only the things I don’t have tools for like AC recharging and front end alignments.
    And you can trust me when I say I do it ALL, here’s a picture of my current project that I’m neck deep in. Hope to have it running this weekend.
    Russell likes this.
  9. stumanchu
    stumanchu Stuart
    Portland, OR
    You cant flash a pic like that and not tell me what it is.......so, tell me......what is it??lol.
    BBMS18 and ike72com like this.
  10. ike72com
    ike72com Member
    Charleston SC
    Looks like a pickup truck with a burnt up engine laying in bed but no bed????
    BBMS18 likes this.
  11. BBMS18
    BBMS18 Member
    75 Comet
    Ike is correct, 2004 Ford Ranger Edge (Smoky) that had a engine fire.
    If you Facebook there’s plenty of pictures
    https://www.facebook.com/100034192756085/posts/282371439579279/?d=n
  12. Krazy Comet
    Fix the overheating issue, the rest will buff out.....
    Maybe not...
    I've done A/C work since the '60s & for last few years my own alignments, I would not tackle that Ranger.
    BBMS18 likes this.
  13. BBMS18
    BBMS18 Member
    75 Comet
    Don’t get me wrong, if the AC just needs a can of freon to make it cold again is no big deal but this Ranger will need the system vacuumed to insure there’s no moisture in it and I don’t have a machine for that.
    After doing suspension work I do a home alignment and the shop usually tells me it was really close.
    As for the Ranger, nothing to it but to do it.(y)
  14. Krazy Comet
    Understood, I have a vac pump, can replace compressors, evaporators etc.
    I still ain't touching that :eek: Ranger.
    stumanchu, BBMS18 and Maverocket like this.
  15. 1973Ford
    1973Ford Member
    North Scituate, RI, USA
    1973 Maverick, 76 Maverick
    The smog equipment was removed from this car before I got it. Started cleaning up the engine bay. Also modified the carb adapter plate removing the egr port.
