  1. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    Slow and methodical, I love it.
    Keep us updated on the windows.
  2. Krazy Comet
    I like the fact I roll up windows without having ign on.
    Last year demonstrated for my daughter. Getting out I said... Look!
    This car has feature that you can close windows with key in your pocket.
    plynch, stumanchu, Hotrock and 3 others like this.
  3. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    Replaced the transmission pan seal and filter. I had some minor issues that I thought might be related to dirty fluid or something odd like a stuck valve going on in there. Nothing to report besides some dirty fluid that did not smell burned. Cleaned out the buildup, put the FelPro synthetic TOS18634 seal on, completely dry, and torqued to spec. No leaks. Might be time for a band adjustment.
  4. 71gold
    I'm wiring these to be hot with ign. on/off.
    BBMS18 and mojo like this.
  5. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    Went to the Carlisle car show today and found a lot of cool parts. Never saw this piece of literature before. E093D3F6-93F9-497A-BA3E-0A905E5985A4.png
    CA189HJN and Maverick_Ian90 like this.
  6. 71gold
    still installing the power windows...:smash:
  7. stockish
    stockish Member
    1973 ford maverick
    Cut out torque box on drivers side
  8. Earl Branham
    Lugoff, SC
    Tried to start the car up the other day, would not start. I shot some starting fluid at the carb, fired right up. It ran fine all day after that. Went out today, same problem. Would a bad fuel pump (diaphram cracked/broken) cause this? Fuel pump is about 15yrs old, Summit brand 80 gph.
    Thanks,
  9. x72COMETx
    x72COMETx Member
    Vallejo CA
    Been talking back and forth with Holley tech support on my sniper efi tuning, a member of another group I’m in suggested to run a 1 inch carb spacer and wow did that make a difference, took the car out for a nice cruise today for some learning and ran smooth the whole time, I can say I am finally happy with the upgrade. May look into swapping out my intake to a slightly taller one as Holley stated my intake my not allow enough flow for the throttle body. In case anybody is curious my current intake is a summit racing stage 3 dual plane
    mojo likes this.
  10. 71gold
    finished up the power window install...:bananaman:
    CA189HJN and RMiller like this.
  11. Hotrock
    Munroe Falls, Ohio
    Earl, you didn't give us much information to diagnose your problem. Since the car ran fine after start up, the fuel pump is probably not your problem.
    Is the choke working properly? Have you changed anything i.e. carburetor? Is this a 4 barrel carb with dual feed lines? The fuels now tend to evaporate out of the fuel bowl/bowls much faster than before; therefore you may have low fuel levels on initial start up requiring the fuel pump to fill the bowl/bowls before engine will start.
    yellow75 likes this.
  12. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    If it was a quadrapuke the answer would be easy, all the fuel drained into the intake over night!
  13. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    I slathered POR-15 all over the rust in the battery support apron. Clearly, POR-15 isn't a permanent solution, but should keep the tin worm at bay until I can teach myself to weld and replace the compromised steel.
  14. 71gold
    road tested the power windows today...:drive:...:chirp:
    they did great...:outtahere:
    CA189HJN likes this.
  15. RMiller
    Kennewick, WA
    I have been chasing squirrels with mine. Started cleaning the engine bay to get ready to paint it only to realize I'm no where near ready to do that. With that in mind I have reinforced the firewall for the clutch master, started working on the harness for the EFI and will be ordering the mock up unit from vintage air. That all should get me close to having any modifications to the firewall finished. Next is mounting the radiator, fixing the battery tray, brake lines, clutch line, proportioning valve amd line lock. I can see why "normal" people can't understand why we enjoy this stuff!
    Jaybee likes this.
