  1. 71gold
    sounds like" all you have to do is finish"...:thumbs2:
    Earl Branham and RMiller like this.
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    :biglaugh:You are correct! Problem is there is still so much to finish.:(
  3. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    Anyone know if they're planning on re-popping the tail light lenses anytime soon?
    Earl Branham likes this.
  4. RMiller
    Kennewick, WA
    Bought a Vintage Air mock up box and working on placement. I wanted to avoid hardware through the firewall, it's such a pain in the seat muscle to work with. With that in mind, I started out thinking I would build a second bracket to attach to the firewall. That consumed a few hours and I finally came up with these, weld them in place and done!
  5. RMiller
    Kennewick, WA
    Good try but not going to work very well. If I continued on that path I'll need a toddler to install the top nuts or leave it so low the passenger will need to have tiny feet for any level of comfort! Time for a reset and try again on the next plan.
  6. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    Decided to do a tune up on my maverick as it was running rough...that quickly spiraled out of control. Today the car got a new intake, new demon 1901 carburetor, new fuel lines, new oil, new spark plugs, new distributor, and new brakes. :rofl:
  7. mojo
    So, how does it run now?
    Shorty and ike72com like this.
  8. William623
    William623 Member
    Orlando
    Not running quite right just yet, acceleration isn’t as good as I would like, have to adjust it some more.
  9. stumanchu
    stumanchu Stuart
    Portland, OR
    Ya cant even go thru the fast check lane with that many items!
  10. William623
    William623 Member
    Orlando
    Spent a few hours working on the car...could not get the demon carburetor to run right. It would have a random backfire through the carb. Checked and recheck timing on the car, air fuel mixture, vacuum leaks, etc... spent hours troubleshooting, even called demon tech support.... eventually gave up and bought a rebuild kit for my edelbrock and now it runs great.
  11. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    The squirrels are my constant companions while working on my Maverick.
    RMiller likes this.
  12. CA189HJN
    First time I have heard such. My own Street Demon was bolt-on and forget. You may have gotten a bad one.
  13. William623
    William623 Member
    Orlando
    That is what I am thinking.
  14. 71gold
    my neighbor bought one and couldn't get it to run right. they said it had been bench tested but when they got done troubleshooting it they found that one of the ports wasn't drilled all the way through, had the needle and seat in but no hole...:slap:
  15. 71gold
    took Patches out for a road test after a transmission cable adjustment...:drive:...:chirp:
