  1. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    The computer triggers a relay, that then feeds fused battery voltage to the pump. All in the trunk.
    I have an older Ford factory EFI system with a return. Would I just cap the return if I go with the Holley 12-205? I would love to upgrade to the in-tank pump and restore the tank vent system.
  2. 71gold
    what fuel pressure does your EFI system require?
  3. Krazy Comet
    Original ford EFI system operate at approx 30 psi & 39 psi at WOT. The OEM Walbro electric pumps used are all but bullet proof, easily operate 150K without issue. Supposedly not designed for PWM, I've heard of them being used for such. Dead ended, with 12v supply, I've seen 125 psi.
    Dayum :eek: & I was upset that a kit to rebuild the original Carter fuel pump on my Cobra was $49...
  4. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    When I tried to drain my coolant, the petcock refused to open (yes, I was turning it the right way).
    Now it's leaking; fun times ahead.
    Sometimes I hate this car so much.
  5. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    Has anyone done a write up on the installation of the
    Holley 12-305 ?
  6. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    put in my radiator and elect fan.
  7. 71gold
    BBMS18 likes this.
  8. roblaw
    roblaw Member
    !973 Maverick 302
    Rebuilt doors: pulled and greased regulators and latch mechanisms, new window channel weatherstripping and beltline felt, new hinge pins. Has a cool, solid door thud now, Satisfying project. MIG welded up drivers rear floor pan, fabricated myself. The only real rust on my floors. Next up, rear lower quarters.
    CA189HJN likes this.
  9. CA189HJN
    Did you take any pictures?
    ike72com likes this.
  10. roblaw
    roblaw Member
    !973 Maverick 302
    I assume you meant the along the process, no I didn't. Sorry
  11. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    This weekend I found a broken bolt in the front of the head to attach the intake manifold. Tried to drill and extract....and the extractor bit broke. Please excuse me while I go cry in the corner.
  12. ike72com
    ike72com Member
    Charleston SC
    Well at least its yours and not someone else.
    And yes its happened to me. Water pump hole.
    Gonna need picture for suggestion on moving forward.
    Maverick_Ian90 and BBMS18 like this.
  13. Maverick_Ian90
    Northeast
  14. ike72com
    ike72com Member
    Charleston SC
    Thats gonna take some work.
    Hummmm??????
    I,d just reinstall intake and keep fingers cross.
  15. Maverick_Ian90
    Northeast
    I thought about that too. I've also been thinking of getting aluminum heads. My main concern if I do get that bolt out is whether the hole is hogged out.
