  1. Ron45922
    Ron45922 Member
    regina sask canada
    1973 comet 302,29000 miles auto air, 2009 shelby kr ( last red one built , 2500 miles)
    thanks,,was not sure of removing side markers lights but when was patching all the trim holes decided to do it,,took two years to finish,,happy with results ,,moved mirrors forward, added grabber spoiler , put in power disk brakes, floor shifter , tach from tim,,220km speedo ( I'm Canadian eh! ) alot of sourcing , mags hood scoop but it came together,,and she has a bit of power ,,331 stroked , aluminum heads alum intake posi rear end,,i wasn't IMG_1329.jpg IMG_1331.jpg happy with color of interior at first ,,but now i am ,,
    ike72com, mojo and Shorty like this.
  2. Russell
    Russell Orejano
    New Mexico, 88022
    Maverick
    I know this is an old p0st, sorry, but I had an uncle horder...died in the war, just wouldn't let go of his hand grenade...
  3. 464925
    In my Mav.
    Maverick 1973-Pure Muscle.
    Put. White letters yo my tires. :happy:
  4. ike72com
    ike72com Member
    Charleston SC
    Chased tail-light, turn signal and brake light problem for several days.
    Found out after all these years how inportant a funtioning turn signal switch is.
    New switch and everything works. And easy to replace!
    71gold and BBMS18 like this.
  5. 71gold
    adjusted the front coilover shocks today. had to pull tire, drop lower a arm and disconnect the sway bar to get it out. after doing both sides it sits about 2" too high. to do that adjustment I have to remove the shock and raise the top mount 2". good thing it's an adjustable top mount and not fixed. nothing but a thing.
    ike72com likes this.
  6. mojo
    Have you had this setup /coil-overs since going MII? I thought adj. units were adjustable w/o removing a lot of suspension -- figured the tire would need removal...
  7. 71gold
    as far as adjusting the damper that is just turn the knob for ride comfort. when you adjust ride height the top mount needs to be moved up/down. in my case that is complicated by the 2" drop spindles I installed later.
    mojo likes this.
  8. 464925
    In my Mav.
    Hello. Thinking. And asking. It's more easy and cheaper. Get 300hp. From a 302 1973 carb , only mod 4 barrel. Ir a 5.0ho 1995? Stock? :thumbs2:
  9. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    A 73 302 is not going to see 300 horsepower with just a four barrel.
    464925 likes this.
  10. 464925
    In my Mav.
    Of course. The question is. To start to modify. actually have the 302. and think buy the 5.0ho.
    RMiller likes this.
  11. Hotrock
    Munroe Falls, Ohio
    You did not indicate if you were planning on converting the 5.0L to carburation? Assuming that is the case; your decision should be based on the condition of either engine.
    The 302 has the advantage of already being in the car and paid for. The 5.0L has the advantage of a roller cam.
    Do you plan on rebuilding the short block regardless of which engine you choose? Perhaps it is a matter of just leaving the short blocks as they are if they are in good shape not high mileage and not consuming oil, etc. Either engine if in good order, can produce 300hp with the addition of cam, heads and intake CHI. You just select either a flat tappet or roller camshaft in combination the the heads and intake. That is the quickest and easiest way to more than 300hp. How much more depends on how much you want to spend on these three items.
    Regardless of which engine you choose; you need an electronic ignition! :thumbs2:
    464925, BBMS18 and Krazy Comet like this.
  12. Krazy Comet
    Dismal Swamp
    With a good set of heads(think aluminum), either will make well past 300Hp. At minimum you want a set of GT40 irons.
    The '95 HO roller cam while fairly mild, is light years ahead of any stock cam from the '70s. With good heads, intake & free breathing exhaust, 300Hp would be easy.
    Twenty years ago, Trick Flow was advertising their Twisted Wedges would add 75 Hp to a otherwise stock 5.0 HO. After trying a set in '00, made a believer out of me.
    464925 likes this.
  13. William623
    Orlando
    1973 ford maverick grabber
    Met up several other maverick guys today and had a blast.
  14. PirateSteve
    PirateSteve Member
    Las Animas county Co.
    1972 Maverick 2dr, 302 automatic. 1974 Comet 4dr, 250 automatic.
    I bought a 74 comet sedan time capsule.
  15. Earl Branham
    Lugoff, SC
    Finally got the Maverick delivered to the body shop to get some minor bodywork done. He's going to fix the trunk drop off, above the pass. side tail light, and the usual quarter panel stuff. He is also going to fix the pass. side inner fender, under the battery tray. Someone before me tried and failed to fiberglass it, and it is nasty.
    This body man does superb work. Worth the wait.
    William623 likes this.
