  1. 71gold
    going to cut the pedal arm and add 1' into it.
    Earl Branham and BBMS18 like this.
  2. 71gold
    got the pedal cut and reassembled...:bouncy:
    a little more filing, primer and paint then it will be ready to reinstall.
  3. 71gold
    dropped the pedal off at the body shop for painting...:yup:
  4. Red 5
    Red 5 Member
    1977 Mercury Comet 4.1L Inline six
    Finished putting down new Acoustishield, ordered some paint for the interior, and set the new carpet out in preparation for fitting and trimming.
    464925 and ike72com like this.
  5. ike72com
    ike72com Member
    Charleston SC
    Attempted to clean garage!
    Sore back kicked in:cry:
    RMiller and BBMS18 like this.
  6. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    I always say if I cleaned for 5 minutes, it’s a win!
  7. ike72com
    ike72com Member
    Charleston SC
    :clap:
    BBMS18 and Krazy Comet like this.
  8. 71gold
    got the pedal arm painted and when I went to install it I broke one of the new bushings...
    ...:slap:...
  9. ike72com
    ike72com Member
    Charleston SC
    Glad it broked while installing and not on your test drive.
    I,m confident you,ll work it out Mr Frank.
    71gold likes this.
  10. Bumble1970
    Bumble1970 Member
    Rhode island
    70 Ford Maverick grabber 6 cyl
    Wanted a center console but didn’t want to pay $150 so I made one. My first attempt... not perfect but looks good in the old Mav... made it for about $30. 350D37FC-64E7-4B12-9E0A-9DE42336493E.jpeg
    Russell, Red 5, stumanchu and 5 others like this.
  11. 71gold
    had to drop the tray and column to get the pedal and switch installed. buttoned everything up and ...no brake lights...:slap:
    tear it out tomorrow and see why not...:bouncy:
  12. 71gold
    got it back together...took it for a :drive:...:chirp:...all is good.
    ike72com likes this.
  13. mojo
    Where was the extra material added? What was reason for increased length of pedal? Have any pic b4 it was painted/coated? I'm guessing this was done to bring/reduce pedal height to floor? Interesting!
  14. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    Finally put the replacement fuel pump on and got the car running again- YAY!
    Then spent some time using plasti-fix and got my glove box dash section glued back together. It had broken into 3 pieces when it came out. Hint, try to leave the steel lower cross bar on the plastic if you are taking this part out to support the thin areas. Found some space above the a/c heater box to hid the ECM, so will get that all tucked in before getting the dash back together. Have to do some cleanup on the cracks and will paint it before it goes back in anyway.
    Plasti-fix works great (thanks BBMS18 for the suggestion), may start fixing a few other things with it as time permits. Even used it to remake a couple of tabs on the dash section that were long missing. Think it will work on my grille to remake the tabs that attach to the hood latch as those are the only broken parts on the grill.
    BBMS18 likes this.
  15. BBMS18
    BBMS18 Member
    75 Comet
    You’re welcome, glad it worked for you.(y)
