  1. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    What do you mean by lower, are you referring to it sitting lower for tunnel clearance? Never got around to fitting mine before acquiring the TKO. That behemoth had clearance issues! Ended up reworking the tunnel for it.
  2. 464925
    In my Mav.
    Maverick 1973-Pure Muscle.
    I reworked the crossmember more than 2 times. first hit the tunnel and had vibrations. second hit down when enter to my house.
    RMiller likes this.
  3. RMiller
    Kennewick, WA
    Scott Drake perches, bolts spacing is off, need to file the holes so they will drop in and looks like they will need work to clear the welds.
    Comet79 likes this.
  4. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    Picked up some nice parts today! FC6085F8-18AC-4B77-94E4-74FAD724A50F.jpeg D72316B5-5EB7-46B2-96DA-B676EB3D1FC2.png 9383AF19-F4DE-49EA-A4BE-4A5EE85F7A7C.jpeg E9286012-162F-40CC-8FE8-FD4C8278D77F.jpeg
    Russell, 464925, 71gold and 2 others like this.
  5. 71gold
    got a set of E-brake cables...
    thanks Dennis...:Handshake:
  6. 71gold
    got the E-brake cables made up and installed today...:bouncy:
    these were my Wilwood rear disc brakes.
    Comet79 likes this.
  7. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    I received the new fuel pump and dug the tank out of the attic, but spent most of the day cleaning the shop to make room for the tool skyscraper
    3EAD4BEA-341A-4618-8855-85C02C9B2711.jpeg 9D653BC6-51B7-472B-BBD9-3FF550FBF5ED.jpeg
    464925 likes this.
  8. mojo
    Nice tool chest! Is the picture taken b4 the shop was cleaned or after?
    BBMS18 and Hotrock like this.
  9. BBMS18
    BBMS18 Member
    75 Comet
    Thanks, it’s a big upgrade from what I had. Doing my best to organize but it’s a heck of a job.
    I cleaned the west bay, the picture was standing in the west bay looking east so you’re seeing the side where a tool & parts truck collided.:biglaugh:
    My friend is coming over this morning to help put up some steel sheeting on the ceiling...
  10. 464925
    In my Mav.
    My new boss 302 crossmember. My car has a problem ,but this crossmember seems to solved it and thik work really well.
    IMG_20210313_173250135.jpg IMG_20210313_173124859.jpg IMG_20210313_181533911.jpg
    Hope You can read the book
    Hotrock likes this.
  11. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Finished my Daughters 72 Maverick Power Window Conversions ..Been promising her for 3 years ( finally) Rigged it so the actual stock window cranks are the switches . Looks stock and works well. We've done six cars now and they were all a hit at the car shows. Nothing new on my own 70 Maverick since the new transmission .
    Cometized
    Chip
    71gold likes this.
  12. 71gold
    got the new float for the fuel sender installed...:drive:...:chirp:
    this is looking through the hole where the other E-pump was installed.
    this is the Holley 12-305 EFI pump/sender combo.
  13. Cemeyer
    Cemeyer Member
    Colorado
    75 Maverick Grabber
    Finished getting my Cold Case radiator/electric fan installed and wired along with the new CVF pulleys and shorty water pump.
  14. 71gold
    took my new float for a road test today. went about 30 miles and it reads about 2 gallons more than I have in the tank.
    on a side note...
    my E-fan never came on for the whole trip...avg. temp was around 171 degrees. outside temp was 60 degrees.
    :drive:...:chirp:
  15. Cemeyer
    Cemeyer Member
    Colorado
    75 Maverick Grabber
    Got the KYB (Nissan) rear shocks on. Much better feel, than the Monroe air shocks that were on it. Worked more on carburetor, found PO left a bolt out of #8 port. Major vacuum leak. Worked over the throttle cable mount to actually use the hole.
