  1. 464925
    In my Mav.
    Maverick 1973-Pure Muscle.
    any chance this headers fit on my mav ? 302, gt40 heads. t5, z bar clutch.
    nor sure what car but are stock on a 302 engine
    I want shorty headers no long.
  2. yellow75
    Tillamook Oregon
    No chance unless you shave your shock towers even then it would be a tight fit. Hedman 88400 fit but will need some fitment help at the collector , you can do a search on here about shorty headers , others have used Doug Thorleys and had good luck with them for fitment
    Krazy Comet and 464925 like this.
  3. Krazy Comet
    Fox body, 5.0 Mustang headers.
    Those have far more clearance to strut tower, won't fit Mav/Comet.
    BBMS18 and 464925 like this.
  4. bryson123
    bryson123 Member
    california
    1972 MAVERICK GRABBER
    Casted my kicker panels and fitted them for jl 5 1/4 speakers. The speakers only stick out about 1 1/2 inches. Will wrapped these in black vinyl to match my other panels.
    464925 likes this.
  5. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Tried looking for a switched 12v source that has voltage while cranking… still looking
  6. Krazy Comet
    Under hood, AFAIK there isn't one.
    The power feed to coil can be used to drive a 12v relay that switches battery power. How my Comet is wired.
  7. 7D2 Grabber
    7D2 Grabber Member
    Thanks, I had a bad starter solenoid which caused a bunch of mysterious wiring gremlins. Like the ignition wiring (red w/green tracer) to act funky. New solenoid corrected it.
  8. Comet79
    Comet79 71 Cometa
    Northern California
    71 Comet
    Where are your pics Lol
    464925 likes this.
  9. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    fuse #1 has a constant 12 v at all times.
  10. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    removed all my temp wires with alligator clips and wire nuts from under the hood. Soldered and heat shrinked it all up.
    7D2 Grabber likes this.
  11. Krazy Comet
    I had that happen on my Cobra, would have to smack solenoid to shut it off.
  12. Comet79
    Comet79 71 Cometa
    Northern California
    71 Comet
    They sorta look like Foxbody headers
    464925 likes this.
  13. William623
    Orlando
    1973 ford maverick grabber
    Saw this on FB market place this morning, drove over and picked it up for $50. Internals looks good, needs a new input shaft and rebuild and it will be good to go! 01AD3B0A-3446-401F-9A6F-11A0CFD255FD.jpeg 62A85C69-8A72-4A2F-9497-25184DA6655A.jpeg
    Comet79, 464925 and BBMS18 like this.
  14. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    Good score, the bellhousing alone is worth twice that or more.:thumbs2:
    What’s wrong with the input?
  15. William623
    Orlando
    Couple of chips on one of the input gears. All the other gears are in fantastic shape though. The main shaft will need to be replaced as it has some damage to the rear splines but It came with a replacement. I probably won’t even end up using that bellhousing as I have an early one to run my z bar set up.
    BBMS18 likes this.
