  1. Krazy Comet
    Dismal Swamp
    Vibration damper, Knock it off and keep on trucking. Best would be install solid U joints & have assembly balanced.
    Russell likes this.
  2. CopiousGull77
    CopiousGull77 Member
    Nebraska
    77 Maverick
    Cool , we'll go that route. Thanks !
  3. dyent
    dyent Member
    vancouver bc
    Been working with Walter Federline (Federline Products) the past year on his Billet Aluminum Hood Hinges for our Mav/Comets and I finally got his prototype installed. He may perform some "minor tweaking" based on my test/trial fitment prior to full production, but they are great! If you are interested, message me and I will pass along Walt's information, he already produces same billet hinges for other classic Fords. Incorporates a self locking device so you can eliminate the hood prop rod.........
    David
    P1020402.JPG P1020431.JPG P1020432.JPG P1020433.JPG P1020434.JPG P1020435.JPG P1020436.JPG P1020424.JPG P1020430.JPG
    464925, Russell, rickyracer and 3 others like this.
  4. dyent
    dyent Member
    vancouver bc
    Also, finally got my Comet front suspension back together, so at least it is back on it's 4 feet........SPC UCA with built in 1" Shelby Drop, cut down Boss 302 Coils, Opentracker Roller Spring Perches, Global West adjustable Strut Rods, Addco 1 1/8" adjustable front sway bar....
    David
  5. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    I got under the Mav with it on ramps and used a remote starter button to a rotate the crankshaft pulley and harmonic balancer. I wanted to have a good look at the markings. I plan to use a piston stop and locate the exact TDC. Just waiting it to arrive. Once I confirm the harmonic balancer agrees with the mark, I‘ll check the timing. The photo is underneath the car looking upward at an angle from the passenger side.
    jasonwthompson and plynch like this.
  6. mojo
    Removed Flex-a-Lite 118 slim line fan after going dead coming from Friday cruise night. I noticed temp gauge 220 and climbing, shut her down 240+, puked about quart coolant. Fan approaching 12 years, guess it served well all things considered for aftermarket unit. I'm not testing the fan too see if it drew enough current to melt a 30a fuse. I made a setup 10 years ago I could remove fan w/o removing radiator -- Glad I did.
    Replacing controller w/ same setup on car now -- want to get it back in service. Fan and controller arrives this coming Wednesday.
    What really pissed-me-off, Hagerty drivers club recovery service vehicle took 2+ hours to come to my aid after texting me several times - on the way. I got to think, I may not renew that service next renewal season. Should'nt have took that long in metro Chicago area.
    Maverick Dude likes this.
  7. 71gold
    got the rack and pinion buttoned up today. juiced it up and bled the air out. looks like it took care of the squall I had.
    raining today so maybe a road test tomorrow...:drive:...:chirp:
  8. William623
    Orlando
    1973 ford maverick grabber
    Noticed my transmission was leaking a bit. Replaced the stock pan with a nice aluminum one and replaced the shifter shaft seals while I was inside the transmission. Put it all back together….still leaking. Found out when I had my transmission rebuilt 8 years ago they never replaced the upper O rings on the transmission cooler lines. Had to drop the transmission down a bit, put on new O rings and now leak free.
    Russell, Maverick Dude and 71gold like this.
  9. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I like to paint the timing mark area white and then sand it off so only the numbers are painted. Makes it very easy to see with the timing light.
  10. jasonwthompson
    Carrollton TX
    rickyracer likes this.
  11. CopiousGull77
    Nebraska
    77 Maverick
    Got a lightly used street demon for 200 $. Had to see how it looked.
  12. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    Gave my babies an nice new "make over" area to park/storage. Before and after pics.
  13. William623
    Orlando
    Met up with a guy fellow car guy who’s family used to run a junk yard in Iowa. Found a few nice surprises in his piles and made a deal. B6CE54F1-AC97-4162-A47D-35CB395B18FB.jpeg
  14. WiscoMav
    WiscoMav Member
    Greenfield, Wisconsin
    My coworker found out I had a maverick and gave me the a promo model and brochure for the Ford dealers from 1970. Take a read of the brochure from the pictures. Kind of funny.
    RMiller and plynch like this.
  15. mojo
    Installed new electric fan, direct replacement for one removed. Had issue two weeks ago , fan quit, leaving me summoning recovery vehicle, luckily I was on lightly traffic street. 30 amp fuse melted , not sure why, possibly fan drawing much more current than fuse could handle or something shorted in E controller. Anyway, replacing all of it, hopefully eliminate it happening again anytime soon. I,m going to test old fan to see if drawing enough to kill 30 amp. fuse. Hopefully, get electrics installed tomorrow and get back on road.
