  1. Craig Selvey
    I was watching that. You did get a good buy. Congrats.
  2. Resto
    Resto Benders Evil Twin
    Yuma AZ
    Removed pasenger door window with a pucker factor of 7. Removed the regulator and cut the door handle skin from the door for shaveing.
  3. Joe Dirt
    Bolting on a old compucar nitrous plate on mine lol
  4. HackleMav
    HackleMav Member
    Belleville IL
    1972 Ford Maverick, 2003 Mercury Marauder (sold) 2011 Ford Taurus
    Think I'm gonna start taking the front fenders off to get them ready for paint. I have this huge list of htings I want to do but none of the cash... damn.
  5. sgaugeguy
    sgaugeguy Bob Kraus
    WILLIAMSTOWN NJ
    I ordered a new alloy valve cover today. I upgraded to the fully polished one!
  6. Joe Dirt
    Threw in some buck twenty five pills gonna see what happens at the track tonight
  7. 71gold
    something different tonight...
    ...P. D. W/ T. S. and blue lights...:yup:
  8. mav1970
    Was that due to an overly aggressive P.D :huh:
  9. diddie
    diddie Member
    indiana
    two 1977 Maverick 2drs.
    Blew the summers dust off getting ready to spend some valuable time with her this winter! Recently recived a Chip for my EEC V to eliminate the EVAP and downstream 02 sensors (thanks to Clintd) so i will get busy finishing the wiring i started last spring:clap:
  10. 71gold
    nope...cop said he thought i was someone else...:hmmm:
  11. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    took in my block/pistons and a bunch of parts to the machine shop yesterday but forgot to bring the harmonic balancer and flexplate in so i did that today..besides that i stared at it for a bit and got a little excited for next spring when ill be back on the road with a new motor that should be just nuts...10sec club maybbbbeeeee!!
  12. kafrompa
    kafrompa Member
    Cedar Creek, Texas
    1971 Comet, 2006 FiveHundred, 2007 Focus and 2008 Ranger XLT
    lock Cylinders
    I just replaced two (2) door lock and one (1) trunk lid lock cylinder (total of three (3) lock cylinders) and I'm about to replace the Ignition lock cylinder OR the ignition switch assembly or possibly both. As of this moment the door and trunk locks work well but the ignition lock cylinder is not rotating in the steering column, it may well be the ignition switch on the steering column beneath the dash or the linkage joining them, I'll find out tomorrow.
    Had any of Y'all had problems of this nature? Any recommendations?
  13. 71gold
    incorrect key...or maybe the...steering wheel lock...has it jammed, try to rotate the steering wheel back and forth as you turn the key...may be a linkage adjustment needed...:yup:
    ...P. D. W/ T. S. and B.Ls. ...:D
  14. kafrompa
    kafrompa Member
    Cedar Creek, Texas
    lock Cylinders
    71gold...The vehicle, 1971 Comet had been impounded and stored in an outdoor compound. I've been applying WD-40 to the Ignition lock in the steering column for three days, it MAY just need more time. I plan on disconnecting the ignition switch from the linkage at the switch in the column today, if that frees-up the key lock in the column I intend to replace the ignition switch that is mounted at a ten o'clock position on the steering column under the dash (if/when I find one). If I cant find an OER switch assy I'll consider relocating the switch to elsewhere on the dash and remove the wirring and the column locking hardware , (but I'd rather keep the vehicle in original configuration). I live in Cedar Creek Texas and be contacted at kagraveliii@yahoo.com or (512)589-2600. Currently the key will enter the lock cylinder but it only rotates 0.25 inch in either direction. I hope this works, I don't want it to end up looking the dash in a race car!...kafrompa ("Garv")
    PS: I appreciate your responce.
  15. nickmav70
    nickmav70 Nick Maverick
    Dallas, GA
    1971 Ford Maverick
    Installed my new computer and finally got the air fuel closer to where i want it... wired up my taurus fan... adjusted my clutch to where it needs to be... installed my drivers side bucket seat...
    was running a tbird computer with my fox harness which is pinned differently... which was causing my car to run way too lean... installed and a9p and it smoothed right out...
    spent more time on the clutch then anything else and more than i wanted to due to an oversight on the installation but one quick call to CNC Brakes and problem was solved....
    made the spacers and all needed for my early fox seats to go in and bolted it in...
    next on the agenda is wiring my head lights and front turn signals and takin it for a ride.... :drive:
