what do I do? monte carlo
Discussion in 'General Maverick/Comet' started by Bob Wiken, Dec 17, 2010.
  1. CaptainComet
    Still interested in getting others thoughts and measurements on a variety of cars.
    I am starting to wonder if a bit of tower sag is really that critical as long as the car still aligns well. Your upper A-arm adjustments are at the bottom of the tower. If your towers are 1/4" narrower than others, that hopefully would mean 1/8" each (could be that just one moved, however). But, 1/8" at the top could translate to less than 1/16" where the A-arms are ... easily taken up with a shim.
    So, that would mean that variances would most affect the fit of a solid bar in my mind.
  2. 71gold
    if these...shock tower measurments... are an exact on all Mav/Comets...this would be the...only exact measurment...on the whole car...:rofl2:
  3. CaptainComet
    :rofl2:... Excellent point!!!! .... We are probably overthinking this, huh? ...
  4. 71gold
    i would think if you are having...sagging shock towers...
    either your...strut rod crossmember is twisted, cowl or radiator support has buckled...
    all this would have been done by the...upper A-arm.
    i think the A-arm would have folded up/down backwards/forwards before it twisted/buckled any one of these.
    ...:huh:...
  5. 71gold
    i read this in an advertisement for strut tower braces...
    "The last thing you want to feel when you're carving the corners is chassis flex."
    i think if you "carve" a corner tight enough to flex the towers, what you feel is...seat pucker...:rofl2:
  6. blugene
    Thst's what I been thinking.. too much thinking.. lol
    :dizzy: I am NOT getting my inch meter on those lol..
    I have slight damage where my right front A arm connects. I may be over worried after all this over thinking. When I removed my fenders the right one sorta poped when I loosened the last bolt. The hood fit good so may be nothing.
    The fact that the upper A arm bolts are splined and short tell me that I can not put shims there. The lower ecentric also only adjusts so much. I will get back to these concerns when I get there. I still gotta paint :rolleyes:
  7. blugene
    :rofl2: Creating a hatchet seat :burnout:
  8. 71gold
    ...another...tid-bit...
    "Their tests revealed a surprise, shock towers do not collapse inward. Rather, they spread apart under hard cornering".
    ... :bouncy: ...
  9. blugene
    MY concern is due to the fact that I run 50's on front.. I don't know if that affects or strains the towers. I don't do any "hard" cornering or at least I don't plan to.
