What do you guys use for sound deadening under the headliner?
Discussion in 'General Maverick/Comet' started by 7D2 Grabber, Sep 22, 2015.
  1. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    What chris has and still is doing for CLD matting over at the DIYMOBILEAUDIO forum
    If anyone is interested
    Ill be doing the same for heat insulation matting
    Controlled experiment testing to get TRUE FACTUAL RESULTS between varying brand products that anyone can use so they dont have to rely on the company saying its #1 (every company says that) or add claims it does this and that well nor go by someones biased opion on X brand they purchased
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Maybe Chris can also do some spelling, grammar, punctuation, and manners testing for you as well.
    71gold likes this.
  3. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Settle down guys, no need to get snippy. I respect all of your real work experiences. I already have Thermo-Tec's acoustical and heat control mats on most of the floor so I'm just looking for a better alternative for the roof. My comet is still in project form so I don't have many miles on it. Thanks again
  4. Supersnake69
    Supersnake69 Member
    1972 Ford Maverick
    I would use Lizard-Skin spray insulation! Its a lot easier on areas like the roof and the results are always promising from projects I have seen and I am using it on my maverick :) There are 2 separate types though so if you want sound control or heat control you can get both or one. A bit less pricey than dynamat but its not as popular! I think it works great though.
  5. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Check out Firewall and Spectrum/sludge from Second Skin Audio.
    Same thing, just cheaper with option to also roll on instead of spray only
    The Sludge is to thicken the substance, resulting in working better due to added mass.
  6. Supersnake69
    Supersnake69 Member
    1972 Ford Maverick
    That looks pretty good! Sadly the thermal cost the same as lizard skin and I already bought the sound control!!! But I'll keep them in mind next time around!
