What do you think is causing the clunking in my rear...
Discussion in 'Technical' started by mashori, Jun 13, 2012.
What's the clunking sound in my rear?
  1. Sway bar binding
    1 vote(s)
    4.5%
  2. Broken shock mount
    15 vote(s)
    68.2%
  3. Shock housing hitting the sway bar
    6 vote(s)
    27.3%
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    it's pretty beat up
  2. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    started hammering and welding
  3. 71gold
    well...I guess that fixed the clunk...:Handshake
    now what are you going to do about the...pegleg shock setup you have...:huh:
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    the plan is to just stick this back up in there and spot weld it, not gonna be easy since the edges don't line up so well but I'll just have to hammer it and get it in there . . .
    the plan is to do the following to strengthen the area up . . .
    this the passenger side
    use an angle bracket and weld a bar across it, probably a square tube, nice and thick . . .
    and have another bracket that will bolt between the removable bracket of the shock and the frame
  5. 71gold
    sounds like a plan...:thumbs2:
    what da water pipe for...:huh:
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    just for mockup, gonna try to use either one inch square tubing or I might try rectangular tubing. if I use rectangular I might be able to notch them at the ends to act as tabs which I can then weld to the frame.
  7. Dave B
    Cut the threads off the gas pipe, they are tapered, making the end you will weld very thin compared to the other side.
  8. baddad457
    :biglaugh: I see someone else doesn't like welding overhead either :D
  9. 71gold
    I don't think he is going to use the round pipe...it doesn't handle side loads well...:D
  10. sdb416
    sdb416 Member
    TEXAS
    No Maverick now
    Im pretty sure you have a bad nest of grimlins hiding in the differential causing all the noises.
  11. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    OMG...this was the most painful annoying frustrating and slow process ....I had to put little tiny welds down and they looked like boogers as the UPS man pointed out...
    So I turned down the heat and turned down the speed which made a huge difference....
    Well, yes they still look like boogers but boogers with more penetration!
    I did some practice welds on this old dash grill that I had laying around. Practiced closing those gaps. You can see on some of the welds I had too much heat, too little speed or moved the MIG head too quickly.
  12. rayzorsharp
    I think that plate may be galvanized or something. I tried welding on one of them a few years ago and it welded like crap!
  13. Mavman72
    Yes that shock mount steel is galvanized. I put some bird s!#t welds on the sprints broken shock mount last summer. Looks ugly but as long as the penetration is good it will be fine Mo...Remember...A grinder is a welders best freind.
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Ok so grind more next time right? I'm assuming that would remove the galvanized coating. May not affect my welds but I'm sure my lungs and nostrils will appreciate it.
  15. darren
    Tell me your a better doctor than welder Mo!! :D
    I aint any better but figured Id poke fun at ya anyhow. :Handshake
