What do your prefer for tires ... Shiny or Flat?
Discussion in 'Cosmetic' started by dmhines, Jul 26, 2006.
How do you like your tires?
  1. Glossy
    30 vote(s)
    57.7%
  2. Flat
    22 vote(s)
    42.3%
  1. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    In between, glossy looks over powering, and flat looks dirty or "blah". I use Black Magic and then wipe it off with a clean rag.
  2. blugene
    [​IMG]I have not ever seen oxidation on my tires, just the words "BF Goodrich".:D
    I like the shiney look, but yet again, not too shiney, got to wipe them down after the spray.
  3. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    We had a lovely seminar on rubber stuff here at work a while back. The brownish stuff that appears on your tires is actually there to block some of the UV rays and keep the rubber from decomposing from sunlight. Most of the tire shine stuff makes the rubber very soft and wears it out faster not so good. What you want is something that coats and has some UV protection. The product shouldn't have any solvents or cleaners or anything even remotely oil based, because that will eat the tires up real quick.
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Wesley's Bleech-White removes all the brownish stuff .... so is Wesley's not a good for your tires?
  5. tim keck
    sharps chapel,Tn
    For a clean,but not super shiny look,use Pledge furniture polish.Lemon smells the best.:D Just spray some on a CLEAN tire & wipe it off,gives a nice look.(y)
  6. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    I'm not sure. Probably not too bad though. The way most of these "weekend warrior" type cars go through tires you'll probably run out of tread before sidewall integrity ever becomes a concern.
  7. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I used to like real glossy, Now I like um in da middle but lean more towards the flat but clean look.
    Dan @ roundup
  8. mean_maverick
    that's something to think about... hmm..
  9. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Read the labels...
    Most of the stuff made for tires or rubber has preservatives and UV block in it.
    Therefore your tires are not in danger from using flat, semi-gloss, or glossy if you are using the right stuff.
    Now if you go and wipe your tires with 10w30 or lard, then you may be causing deterioration.
    Personally I like to wipe them with raw bacon. ;)
    Dave
  10. sierra grabber
    sierra grabber Certifiable
    northern nevada
    keeps the muslim extremeists away from your car?:biglaugh:
  11. blugene
    Crawdad bait? :biglaugh:
  12. Jean Doll
    Palmerton, PA
    I can just see every dog in your neighborhood chasing your car down the street screaming " It's Bacon!!!".:D
  13. dmhines
    Cumming, GA
    Shiny took off to a big lead ... but natural flat is catching up quick! :)
  14. blugene
    Yea but flat is going flat, lol
  15. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    yea but you dont get far on a flat :biglaugh:....i like to run them at what ever they say on the sides of the tire :evilsmile :rofl2:
