what flywheel to use
Discussion in 'Technical' started by driftwood, Feb 22, 2013.
  1. driftwood
    driftwood Member
    aberdeen,oh
    95mustang gt convertable 74 maverick, 75 four door,71 parts car, 67 couger 71 jav. sst
    scuze me ,bought flex plate :) and i trashed the 250 one when i took it out.stupid me didn't realize it could be used with the v-8 junked the 250 cause there was 3 HUGE holes in the block where the guy rapped it out so tight he blew the back two pistons and rods thru the side of the block. then lately found out guys are looking for the manifold that was in great shape.oh well
  2. Krazy Comet
    The 250 flexplate is zero balance, can't be used with a 289/302...
  3. John Holden
    John Holden Member
    NJ
    Hey you guys are right. Good catch! I forgot about the balance. Again, good catch!
  4. driftwood
    driftwood Member
    aberdeen,oh
    lmao all these answers and still not for sure what i should buy or take back and buy. anybody for SURE know what i need. thanks a ton for the info
  5. baddad457
    Chances are you need a 28oz/in, 157 tooth flexplate here. There's a lesser chance you'll need a 28 oz/in 164 tooth flexplate, it all depends on the bellhousing on the transmission.
  6. John Holden
    John Holden Member
    NJ
    I just edited my last post so it's not confusing things. If you're using a trans from a 250 and installing a 1977 302 all you need is a 157 tooth flywheel with 28oz imbalance.
  7. x72COMETx
    x72COMETx Member
    Vallejo CA
    i have and 85 302 engine im building and im going to use the trans of my 250 i6 can i use the flywheel on that or do i need a dif one sense its an 85 block
  8. Mavman72
    You will need a 50 Oz imbalance flex plate...
