What Hedders are you running?
Discussion in 'Drag Racing' started by valleyracer, Jan 22, 2010.
  1. Hooker 6901
    45.5%
  2. Hedman 88300
    16.4%
  3. Other
    38.2%
  1. maverickmadness
    maverickmadness Member
    ala
    1973 maverick grabber, 1972 maverick grabber,1974 maverick grabber,
    hedders
    ive got flowtech hedders on my purple mav..cant remember the part number tho..made by hooker i think. fit perfect, easy to install and remove. 302 motor
  2. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    Hooker headers..those were not easy to install,some hammering was needed to fit lol
  3. olerodder
    olerodder Member
    NorCal
    RadMav,
    Do you have any pictures of the headers you built. One passion I have is building headers.....................here is a set I built for my Model A hot rod.
  4. Alan Duke
    Alan Duke Member
    Houston, TX
    1973 Maverick
    Motorsport used to offer the chrome set I have on my car. Dont remember the PN though. Good fit and went in pretty easy.
  5. olerodder
    olerodder Member
    NorCal
    RadMav,
    The headers look really nice, great job!
  6. blugene
    Wow, same brand and age as mine. I wrapped mine a couple of years ago. Some day I will experience the difference.
  7. mbong66
    mbong66 Member
    Phoenix AZ
    1970 maverick
    I am running the 6901 headers but they don't match up very well with the vic Jr heads I am using. does any one make a header that have the sqaure port or an oval port wider then 1.40in without having to cut the flange off or have it custom made
  8. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    I have yet to see anything close to the port without going the cussstom route! There is a Hooker 1 3/4 that some have used on here but I don't have the part # handy. I'm sure someone will chime in on this?
  9. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    1-3/4 tubes
    Hooker 6802 for the 66 to 70 351w swap. 1-3/4 tubes.
    Don't do this unless you can fab because that what it takes.
    I had some pictures posted at one point in time but I know I'm not the only one who as done this mod.
    Speed costs! How fast do you wanta to go?
  10. bossmav
    Harrisonburg, Va
  11. svopro
    svopro Member
    Rochester Hills, Michigan
    Are you running a cable clutch or Z-bar ????
  12. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Cable clutch with a lakewood scattershield
  13. mean_maverick
    run 6901's with anything 302 based....
    going with 6208's in the '73 with my 351w :drive:
  14. mean_maverick
    the pics are gone..... :(
  15. tim keck
    sharps chapel,Tn
    ran 88300s on the 4dr, had some Caslers on my '73 Grabber in HS.
