What is the best cable clutch conversion kit to use?
Discussion in 'Transmissions' started by 69GT, Jan 29, 2004.
  1. Timmyothy
    Timmyothy New Member
    bellevue wa
    1975 w/ 302 4spd
    ok help again and thanks for all the help in the past
    ok i need to do a cable clutch conversion its a 75 mav, 302 ( very built ) center force clutch and p. plate, and t-10 trans i'm looking at a cable conv kit
    http://www.moderndriveline.com/catalog/clutch_cables.htm
    now it seems to me that everyone is talking about the cable being set up to "pull" the pickle fork rather then "push" it like ours needs. Am i just miss understanding what this thread is talking about?or do i need to set this up so that the cable will have a solid mount to the transmision and " pull" back? or a solid mount to the bell housing and "push" it back?.
    please pardon my ignorance on this
    thanks
    Tim
  2. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    My '86 2.3 bell housing has the clutch cable adjustment on the bell. It's very nice since you don't have to put the adjuster on the firewall. The only PIA is that it interferes with the pinto cross member. Anyway, just some more 80s T5 trivia knowledge.
  3. PGARFDS
    PGARFDS Need more room!
    Near Tulsa
    702dr, 2-72 302 Grabbers, 72 302 2dr., 72-200 2dr., 73Grabber, 74 2-dr, V8 4spd Stallion, & rusty Stallion
    Timmyothy,
    The cable clutch systems are only for bellhousings that were originally made for cable activation. Pinto's, Mustang II's, and fox body cars(79+ mustangs etc)had clutch cables. I have not heard of anyone converting a traditional push type pickle fork bell housing to a cable system, but I'm sure someone has at least tried.
    Most of us are trying to use a T-5 or modern style transmission with a bellhousing intended for cable activation in our Mavericks. That is also what the moderndriveline kit is for.
    Does your clutch system work now?
    ATOmonkey,
    Great start! I can't wait to track the progress on the cardomain pages.
  4. Timmyothy
    bellevue wa
    1975 w/ 302 4spd
    clutch cable
    no at this poinTimt the stock set up will not work we are now looking at going hydrolic if the cable idea wont work, any ideas there?
    thanks
  5. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
  6. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Who the hell needs a cable??????
  7. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Shadow, what is that? What is connected to what ever it is?
  8. ShadowMaster
    The ShadowLands
    1969 1/2 Maverick
    That is the Wolfe Racecraft pro clutch pedal assembly. Welds to the floor (preferably with a crossmember welded in under it) and uses a linkage rod for the clutch.
  9. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I have a very slight problem with my brake peddle & the rod that comes out the brake booster dont line up with mu brake peddle. The rod needs to bend toward the passenger side about an inch to allow the peddle box to line up with the 4 studs on the firewall. Is there a difference in the rod for power brake boooster & manual brakes? The peddles came out of a car without power brakes & I have power brakes.
  10. maverick1970
    maverick1970 MCG State Rep
    Missouri
  11. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Thanks, that's what the difference is. This has been a nightmare. I guess my fabrication skill has increased. Any ideas on how to move the rod over. The rod that goes with the peddles will not work either if I read the right.
