What is the best way to maintain upper A-arms?
Discussion in 'Technical' started by ratio411, Oct 27, 2007.
Best way to access grease fittings in the upper A-arms?
  1. Cut nice [i]round[/i] holes and seal them with grommets, only to be removed for service.
    39.1%
  2. Use 90* grease zerks, even though the wheels may have to be removed to service, it's worth it.
    56.5%
  3. Hack the holes, because greasing the arms is better than worrying about some little holes.
    0 vote(s)
    0.0%
  4. Grease fittings!?! What grease fittings?!?
    4.3%
  1. blugene
    I know that and you know that, but the guy with a torch or no drill won't care...and when they burn the one and only hole saw they bought cause they didn't know how to use it, back to the hack torch. :biglaugh::16suspect :cry:
  2. blugene
    All your post wasn't there when I posted the previous one. :hmmm:
    How about a dremel to clean it up?...Then plug it.:huh:
  3. bmcdaniel
    For some reason I had a double post and the first one wasn't complete, so I deleted it.
    The chisel left some big, ugly, not very round holes. I figure I can weld in washers with the correct size ID, using my grease gun fitting to align them.
  4. rayzorsharp
    Yes, I believe that should work out great too.
  5. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I don't know if anyone has noted this...b u t that picture of the hacked shock tower doesn't even have greaseable fittings in the bushings, it's got the plugs!
  6. rayzorsharp
    LOL...they probably cut it out so they could spray some wd40 on the control arms.
  7. PaulS
    Is it possible to do like the heavy equipment folks do and run metal tubes from the control arms to some place accessible and terminate them with zerk fittings?
    It would take some brass fitting to screw in to the a-arm bushings instead of a zerk fitting, some 1/8" tubing and a fitting and zerk, say, under the hood on a fender?
  8. blugene
    Kinda what was discused in post 5 (which includes a previous posting). Nothing could be hard plumbed as there is movement.
    I like the idea of using some rubber bushings, but have never seen one which is actually working in our cars.
  9. bmcdaniel
    One of the suspension companies (Moog?) has what they call Problem Solver bushings for our cars. Converts the control arms to rubber bushings like the GM cars. Supposedly once you install them you can't convert back to metal bushings without replacing the control arm.
  10. lastchance
    lastchance Member
    Hingham , Massachusetts
    I have the Moog kit ,have not installed it yet. As i am doing the Shelby drop, they
    fit better in the tower then the originals. I got this information off this site.
  11. Thack
    Thack vision advicator
    Moreno Valley Ca
    This must be what I saw I just thought it was a late model a arm. I can give you a good reason to change to this type. This has been a topic in the mustnag magazines. As your stock A arm rotates threw it's travel one side screws in and the other side screws out thus changing you caster. If both sides of your car hit a dip at the same time one arm moves forward and the other back. I'm sure it's not much but, your wheel alignment is changing as it moves.
  12. bmcdaniel
    Moog # K8233
  13. blugene
    I want em!! Thanks bmcdaniel :cool:
  14. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    That's the exact kit that I bought from CarQuest, way back in the day when I first got the Comet.
  15. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    I have the moog kit, need a big press to get them installed right, they wpie out the thread in the controll arm which is why you can't go back, but all summer, no noise, which is more than I can say about the old bushings which were greased weekly. I thought the moog kit would have been brought up sooner, I think there are others who have done it. My towers were butchered with an air chisle, I cleaned the holes round with a torch, made a few plates out of heavy flat stock and drilled holes for the zerks and welded them in before I went with the moog bushings
