What is the best way to maintain upper A-arms?
Discussion in 'Technical' started by ratio411, Oct 27, 2007.
Best way to access grease fittings in the upper A-arms?
  1. Cut nice [i]round[/i] holes and seal them with grommets, only to be removed for service.
    39.1%
  2. Use 90* grease zerks, even though the wheels may have to be removed to service, it's worth it.
    56.5%
  3. Hack the holes, because greasing the arms is better than worrying about some little holes.
    0 vote(s)
    0.0%
  4. Grease fittings!?! What grease fittings?!?
    4.3%
  1. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    that might be just the ticket to clean mine up for the time being :Woot:
  2. blugene
    A hole saw? You have to have a pilot for it to stay in place for a circle... Unless I am missunderstanding you.
  3. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    well....your supposed to.....but if youzzzz be real careful, you can get it going :bouncy:
  4. blugene
    This is where I think a dremel works the best...get er dun! :smash:
  5. bmcdaniel
    Hey John, you can use the little hole that the grease fitting screws into as a pilot for the bit. :D
  6. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Is rubber really better in there?
    Seems like that would have some play compared to bushings... Setting aside the arguement about threads turning.
    What about poly?
    Could this kit be had with poly? Or could it be retrofitted with poly bushings?
  7. blugene
    :rofl2: Now that's funny!
  8. bmcdaniel
    Probably no worse than the rubber lower control arm bushing or the rear spring bushings.
  9. blugene
    I am starting to wonder how they would hold up to the weight and twisting. After all the weight is applied to the upper A arm.
    Who has the rubber ones and for how long have you ridden them?
  10. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    thats not a bad idea :16suspect:16suspect:16suspect:16suspect
  11. lastchance
    lastchance Member
    Hingham , Massachusetts
    To locate the hole saw take a small piece of 1/8 steel and take the hole saw you are going to use and put a hole in the plate. Take the plate and tack weld it to the tower positioning it over the rough opening.Now take the pilot out of the holesaw and use the hole in the plate to center the holesaw. Thi trick has worked for me many times when needing a hole a different size . Lastchance
  12. Jamie Miles
    The '72 daily driver has the 90 degree zerk fittings, which actually came with the new upper control arms from Mustangs Unlimited. I found I had to dimple the shock towers slightly from the inside out with a punch, because the zerks were touching the front side of the shock towers. Other then that, they work well.
    The '73 is getting ball bearings in place of the bushings on both the upper control arms and spring perches.
  13. bmcdaniel
    Jamie, are you using the "Opentracker" parts for these? I've considered doing the spring perches myself.
