What is this?
Discussion in 'Technical' started by PAINTANK, Nov 20, 2009.
  1. 71gold
    a lot of manual transmissions had these...
    most of them you had to put the shifter in reverse before removing the key. if the engine was idled too high it would run on after shutting the engine off and when you let the clutch out it would jump backwards.
    if you take it off...keep it....someone (you) may want it for your/their AC...:yup:
    ...:drive:...
  2. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    As per my OLD motor manuel (1969-1975) it is a anti diesel solenoid .
    You have 2 idle settings 600/500 rpms .
    You set your curd idle with the idle screw on carb at 500 rpms
    Then with solenoid ingaged you set your idle at 600 rpms
    The easiest way to set solenoid idle
    1 unplug solenoid
    2 have eng. idle in drive ebrake set to hold car set idle with carb adj. at 500 rpm
    3 loosen jam nut on solenoid plug in solenoid to ingage
    4 turn solenoid like a thimble to get 600 rpms then tighten jam nut
    Your missing the jam nut
  3. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    I used a small piece of hose to compensate for the missing nuts. Then I can use the set screw on the bracket to adjust the solenoid.
    Curb(in drive) idle at 500 makes my car idle like crap, I prefer 650-700rpms to keep it smoother, it sputters at 500. Maybe because my exhaust is so free flowing.
    So I set this solenoid to be @ 100rpm above curb?
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    If you decide to take it off, let me know. I'll be needing one when I put AC on mine.
