what is wrong now???????
Discussion in 'Technical' started by sam03rc, May 21, 2010.
  1. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    well a higher converter i had to get a new one and the lowest rpm one i could find was from tci and it is 1600-1800 so its alittle higher than stock
  2. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Yea... very little.
    Its a bit higher but not a "high stall"
    As far as carbs... each kind is different/easier for each person.
    If you read up on them and understand them then they will be both equally as easy to tune
  3. sam03rc
    sam03rc Member
    gates county, nc
    yea i mean i kind of understand holleys now but ive heard from some that edelbrocks are easier because that there is no floats to set just a basic bolt and turn the idle
  4. Andysutt
    Conway Arkansas
    1972 Comet GT
    The float level still has to be set on an Edelbrock
  5. sam03rc
    sam03rc Member
    gates county, nc
    oh really so it doesnt really matter which one i go with might as well stay in the holley family then since i kind of know what to do with them. so whats the most common holley that will be best for my 302. just a 600 cfm or is that to much for it?
  6. Andysutt
    Conway Arkansas
    1972 Comet GT
    600cfm or less I would say unless you build it up
    Every carb, even a stock carb has to be set and adjusted to run correctly.
  7. sam03rc
    sam03rc Member
    gates county, nc
    ok then thanks andy ill see what my local advance has in stock
  8. spork1o1
    spork1o1 Member
    Michigan
    What are you looking to get out of your setup?
    Daily driver with good gas mileage.
    Weekend driver possible future mild performance mods.
    Occasional street use definite future mild-to high performance mods.
  9. Andysutt
    Conway Arkansas
    1972 Comet GT
    Those stores usually don't keep carbs in stock.
    Just letting you know so you dont waste a trip
  10. sam03rc
    sam03rc Member
    gates county, nc
    its my first car so i want it has to be a daily driver but i want a good bit of performance out of it for it whenever i take it to the track. i just want it to drive at this point
  11. sam03rc
    sam03rc Member
    gates county, nc
  12. mav1970
    For a stock engine, that square bore electric choke Holley 600 is ideal. I had one on a 73 Duster with a 318 that ran 80,000 miles with very little trouble. I would try to sort the problems out with the carb that you have. Do you know any drag racers or circle track racers that can look at it for you? They know Holley carbs inside and out.
  13. sam03rc
    sam03rc Member
    gates county, nc
    no i dont know really anyone that can look at it for me. what about that summit carb?? like its cheaper and all the parts for like rebuild kits and stuff are all same as holley
  14. mav1970
    My guess would be that Holley simply made a carb for Summit Racing. Unless they cheapened some of the internal parts so that Summit could sell it for less, it may very well be a Holley.
  15. sam03rc
    sam03rc Member
    gates county, nc
    true they could of cheapened the parts for that didnt think of that
