what oil should i use in my 302?
Discussion in 'General Maverick/Comet' started by CentralValleyComet, Feb 20, 2012.
  1. scooper77515
    Personally, I agree with Frank on this one. I use 10W-30 in everything.
    It is a good "all-around" viscocity.
    The only thing I "might" add is a qt of Lucas.
    Some of the fastest cars in the world use Lucas, so it can't be all bad.
    I run Lucas in my Maverick because I only start it once every month or three. I hope that the Lucas keeps some of the oil stuck in the upper part of the engine for that long so I am not doing any startups with no lube.
  2. 71gold
    I think they run more of the...sticker...than the product...:yup:
    look at some of the cars...if they ran all the stuff that is on the ...stickers...there wouldn't be any room left for...oil...:huh:
  3. scooper77515
    That seems true, Frank :rofl2:
  4. CentralValleyComet
    CentralValleyComet Member
    West Coast
    73' Comet 302 4-Door
    thank u all. it is daily driver
  5. idrivemav
    idrivemav Member
    texas
    1975 maverick
    My engine is pretty modified and I run brad penn 20w-50 plus a bottle of comp cams break in lube at every oil change I like the extra additives of the break in lube plus it helps with the high valve spring pressure on a flat tappet cam been that way for 3 years now and still has 75psi oil pressure at about 2500 hot
