what proportion valve are you using besides a granada one?
Discussion in 'General Maverick/Comet' started by 2 mav man, Mar 12, 2010.
  1. 2 mav man
    2 mav man Member
    florida
    1970 maverick grabber
    Thanks CaptainComet, I will try the new m/c and see how it works.
  2. mav1970
    I was planning on using a disc/disc T-Bird master cylinder (has larger front fluid well and smaller rear fluid well) but was just going to keep the stock 1970 drum/drum proportioning valve.
    Do you know what the front to back bias is pre-set with the old drum/drum P. valve? Is it possibly even up or still biased towards the front drums? :huh:
    I also have a Wilwood adjustable valve. Did you mount your's in the line going to the rear brakes? As you turn the Wilwood valve clockwise, does it take rear brake out of the car? I've used these in stock car racing but I'm just trying to get a feel on how it is working out for someone using it on the street. :)
  3. 2 mav man
    2 mav man Member
    florida
    I don't have an adjustable valve, I have the yellow 70 grabber running the stock master and prop valve with 75 rear end and disc brake set up. The pedal is very spongy and the rear brakes are locking up first.
  4. PaulS
    If the pedal is spongy then you have air in the system - bleed the brakes until they are firm. Take your time and then sort out what the bias needs. You can't adjust the bias with air in the system.
  5. 2 mav man
    2 mav man Member
    florida
    I've bleed the system twice with a vacume gun I'm wondering if I need to get the wife outside and just bleed them old school. I'm suspect of the m/c needing to be rebench bleed again.
  6. Jerryfow2
    Jerryfow2 Member
    Milltown IN
    1972 Grabber/1972 Sprint/1976 Stallion
    I would be weary of the vacuum gun. Old school works every time.
    Jerry
