what should i do to the engine since im taking it out anyway
Discussion in 'Technical' started by ssquier92, Nov 11, 2007.
  1. 71gold
    ...could be the ...shiftershaft seal...you will need to take it by a trans. shop to get it changed...:yup:
    ...one more worm for the can...
    ...:bouncy:...
  2. 71gold
    you will be taking a chance with the ...new cam...if you don't change the ...cam bearings...:yup:
    ...new waterpump...while you have the old one off...
    ...new timming gear set...while you have the old one off...
    ...new belts...
    ...new hoses...
    ...new t-stat...
    ...6 more worms...:yup:
    ...:outtahere:
  3. 71gold
    ...new cam will also need...new lifters...:yup:
    ...one more worm... or (16) more.
    ...:bouncy:...
    (if i think of anything else i will let you know.):D
  4. ssquier92
    ssquier92 Member
    FL
    1971 grabber 302 v8
    hahaha wow.. yeah i was looking more into the cams and realized it was much more than just slidingt the old one out and slipping the new one in so i kind of dropped that idea.. i was actually planning on getting it painted soon as my budget allowed it but then this came up so i figured as i had it off i would do a few mods... what i have ordered is pertronix 2 ignitor electronic ignition or whatever then the chrome flame thrower 45,000v coil.. should help a little bit.. i already put nice 8mm spark plug wires on it.. then im getting a K&N oval filter with a milled cover.. then a billet chrome alternator.. it should be pretty nice.. most of that is cosmetic but i also am getting an electric fan and removing the one on the water pump.. should at least take off some resistance there..
    should i still be advised to do a new water pump??
    thanks for all the help by the way..
