what should I put in my 302
Discussion in 'Technical' started by pil1sbury, Apr 15, 2013.
  1. bmcdaniel
    Does that $150 include notching the bottoms of the cylinders?
    If your gonna install the crank, rods, pistons/rings correctly you need measuring tools like mics, feeler gauges, maybe a bore gauge. Especially with most of the stroker kits using Chinese cranks and rods. You can't just take the parts out of a box and expect them to fit, you have to measure (and usually adjust) everything.
  2. 71gold
    this is an est. I got a couple months back...$963 parts and labor...
    labor est. $250... * labor $270...* if needed or wanted
    *clearance for stroker crank...$85
    *line hone...$100
    *grind crank...$85
    clean block...$70
    bore block... .040... $120
    install cam bearings...$35
    install freeze plugs...$25
    size rods
    parts est. $443
    Kith Black pistons... .040...w/eyebrows
    rings... Molly
    main bearings
    cam bearings
    full gasket set
    timing gear set
    oil pump...Melling
    freeze plugs...brass
  3. groberts101
    groberts101 Member
    Minneapolis, MN
    wow Frank.. those are pretty decent machine shop prices if they include crank polishing and torque plate honing in the numbers.
