What spark plug wires do you suggest?
Discussion in 'Technical' started by scooper77515, May 13, 2008.
  1. scooper77515
    This is a completely separate question, but what do you suggest for looms, regardless of wires. I have not found the loom that will keep my wires where I want them (possibly part, or ALL of my current problem:oops:).
    Hey Blown...I hope these wires don't make my front end hop off the ground like yours...I need to keep control of the steering while I am cruising the streets:D
  2. yellow75
    Tillamook Oregon
    I have been running the Accel 300s on my car for 5 years never had one problem with them, except they wont make my front tires come off of the ground :hmmm:
  3. Blown 5.0
    MS.
    1974 Maverick
    I believe it has somthing to do with that extra belt i have, Gonna have to check that out.:hmmm:
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    A friend of mine showed me how to make looms using standard wire ties. They stay put and keep the wires separated.
    Scott PM me you email address and I will send you a pic that you can zoom in on.
  5. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    I have Taylors on mine seem fine.
    And on a side note i see you are running a 40 thou plug gap.Seems kinda large for a pertronix.I always ran 30-32 on my Big block with the pertronix.Just curious i was always told the larger the gap the harder the ignition system has to work.Maybee i was running too tight.
  6. maverick5.0
    maverick5.0 Member
    Caribbean/Puerto rico
    1976 maverick,347 stroker,c-4,sm bumpers,frt air dam/73 maverick,5.0 grabbber hood,four on the floor,v8,rear spoiler,...
    accell super stock 8mm on the 76 mav...and accell 300+ 8.8 on the 73 mav...sorensen 7mm OEM replacement wires(Western Auto) on my 289 63 ford fairlane500 sportscoupe... the only performance improvement on the fairlane was the change from points to a 85 mustang duraspark and a gm electronic module with msd blaster coil with small distributer cap and rotor...
  7. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    Taylor's with MSD6AL and a Blaster 2 coil, never any issues with this setup!
    Accel SS coil was fried along time ago.
  8. scooper77515
    valley, could the Accel SS not take the better coil and MSD setup?
    Only issue I had with SS (on a mostly stock motor, of course) was that they were yellow, and I could never keep them looking nice.
  9. PaulS
    The wider the gap - the harder your system has to work.
    You were told right.
  10. scooper77515
    I used to run .046, but I will be closing it up to .036 on this setup.
  11. Columbus Comet
    Columbus Comet Member
    Columbus, OH
    I used Taylor and the looms from mustangs plus. If you get the universal set you can cut and run the wire perfect. I like a nice clean look.
  12. scooper77515
    Hey, Maverick1970, I got that picture, and that is PRETTY COOL...and it will work with any size wire!
    I will have to try that this afternoon and see if I can make it look as nice as yours.
    AND, thanks for providing a good picture to show me how to arrange and route my wires!!!:thumbs2:
  13. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    MSD 8mm for your setup. Gap on the plugs should be no more than .036....you might want to try .032 and work your way up.
  14. maverick1970
    Missouri
    Glad to help! (y)
  15. Bryant
    i also run the accel 300+ wires. they have a life time warente. ive warented them once because they hit a header tube on my mustang. yes im useing the same set on the mav. a friend who went to the school of automotive machineists (SAM) said that they had dynoed every plug wire they could get there hands on and the accel ones made the most power.
