what stock ford wheel will fit
Discussion in 'Wheels and Tires' started by Chadwick powers, Oct 29, 2015.
  1. Shorty
    Shorty Member
    Lafayette, In
    Be careful in regards to the center bore diameter of the wheels. The Ranger steel wheel center hole may be a little smaller than the disc brake center (can't think of the proper term for it.) I had to use a puller to remove the Ranger wheel from my Maverick when I needed the Maverick wheel/tire in a pinch.
    Bruce
  2. SupermanEst1984
    SupermanEst1984 Michael Myers
    Monroe, NC 28110
    '72 2 door Ford Maverick 250 6 Bangin' it
    You're correct the center bore of the wheel may fit on but is a pain to pull off. Sometimes the aluminum wheels will have a small little ridge of a lip that keeps them absolutely snug or your case with the steelies so tight they don't slip back off when needed. You can very carefully take a router with a metal cutting bit and route off this inner lip to clearance the center hub. I know this is a Maverick/Comet forum but I'll show the info I learned via my Chevy S10 days
  3. BillC
    BillC Member
    El Paso, TX
    1975 Maverick
    I'm running 16" Explorer Sport Trac wheels. They are 4.5" backspace and will fit with no mods. I am using 1.5" spacers on the rear and 1" spacers on the front (not needed, I just like the look better). Ranger wheels are also 4.5" back space.
