What tools to keep in the trunk?
Discussion in 'General Maverick/Comet' started by David74maverick, Jan 26, 2011.
  1. mjm0395
    mjm0395 Member
    Everett wa
    1972 Yellow Comet, 1966 Ranchero
    Nobody mentioned a blanket!! Not for keeping you warm, but for the fenders when you are working on it, or on the ground to lay on!:idea:
  2. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    I got a old ratty blanket back there to, to lay on when I need to get under the car>
  3. Jamie Miles
    Alto, GA
    I've had a few
    This, a crescent wrench, vice grips, side cutters, roll of wire, some electric tape, spare tire, jack and lug wrench. Also a couple of old empty gallon antifreeze jugs.
  4. jkc302
    jkc302 Member
    Dearborn, MI
    Toooo many!
    A Cherry Picker!
  5. CaptainComet
    As a sidenote, I saw that you went through a bunch of coils and a module.
    I had the big yellow Accel coils for a while, and for some reason, needed to wire an extra little module in there. I think it was to step down the voltage going to the coil. I forget if it was to save the coil (killed one of them) or if it was supposed to keep the points from burning up too fast.
    Sorry I can't remember any more detail ... long time ago. But it may be something to check into. Might end some trouble for you.
    I switched everything over to Pertronix, and it was a big improvement. :thumbs2:
  6. h2o
    h2o Mad Mav Man
    mexico city
    1973 ford maverick gt 289 v8
    How good those Stanley tools are?
  7. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
  8. mojo
  9. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    Bucket seats or bench?
    Summit and Jegs both have a great assortment of bottle brackets.
    I use bucket seats in all my cars, so I go with the trans tunnel behind the passenger seat angled towards the driver seat for easy access for me.
  10. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    100% agree with fire extinguisher. I keep one in all of my cars. I've had to use it more than once. A little in the way sometimes, but beats watching your car burn down.
  11. mojo
    OK! I will have to see what I can come up with. I shud be able to use the bracket that came w/ the unit and get the fire ext. out of the trunk.
    Thanks for the suggestion.
  12. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    I have a small chromed one that fits neatly in the package tray.
  13. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    i have mine mounted to the trans tunnel on the passenger front side,right in arms reach,i've had 1 of those cheep foam triangle aircleaners catch fire from a backfire and it sucked.
  14. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    Also when getting a fire extinguisher keep in mind "sweep time"............ An average 2.5lb bottle has about 9 seconds of sweep time......... So 1 lb bottle would average under 4 seconds!!!!!!!:16suspect
    Is that enough time?
    I think a 2.5 bottle is more equiped to handle the situation, but still not enough for a comfort factor. I think a 5lber is a better idea, but at the same time not as convenient inside a car.
  15. facelessnumber
    Memphis, TN
    '71 Grabber
    This is true. Mine is about 1.4 lbs. I'd like it to be bigger, but there's the balance of convenience vs. capacity and you just can't predict which will be more important. After my last fire in which I had to dig through the trunk for what seemed like an eternity, (probably less than a minute, but too long!) I leaned more toward the convenience factor. I do have a much bigger extinguisher in my van, but it's a van...
    (Now this thing carries tools...)
