What type of tail lights do you prefer
Discussion in 'General Maverick/Comet' started by zorares, Mar 8, 2012.
Which tail light do you like best?
  1. A
    44 vote(s)
    34.1%
  2. B
    39 vote(s)
    30.2%
  3. C
    6 vote(s)
    4.7%
  4. D
    1 vote(s)
    0.8%
  5. E
    12 vote(s)
    9.3%
  6. F
    1 vote(s)
    0.8%
  7. G
    7 vote(s)
    5.4%
  8. H
    19 vote(s)
    14.7%
  1. zorares
    zorares Member
    Midlothian, Texas
    1973 Ford Maverick
    That's nice! What are those?
  2. Streamliner
    Streamliner Member
    They're called "bestforthemavericks":dancing:
    They're actually late 60's Mercury Cougars:)
  3. maverick75
    I never knew those existed! they look awesome!
  4. CaptainComet
    Here's a better look at late Pinto taillights as they came on a 1979 hatchback ...
    another variation to look at .... unfortunately there is a topless girl in the way
    Another shot of a 79 (and maybe 80?) Pinto
    A google image search will turn up a lot of images for the 77-78 Pintos, too, but I had terrrible luck trying to post links to them.
    Here we go ... an example of those middle year taillights ...
  5. predfan2001
    I got the 76 Pinto lights in yesterday. They are no thicker than the Maverick lamps. I may sell them or use them on another Maverick later. I like them but I'm not going to use them on my car. They actually appear to bolt up the same as the factory Maverick lamps, but the reverse lamp side is larger so the Maverick taillamp panel would have to be trimmed out some.
  6. Fordcustom
    Fordcustom Member
    Callahan, FL
    72 maverick
    I pulled them from a 67 cougar. I unbolted the lenses from the the reflector section. I flattened the back of the light/drilled and tapped for new studs. The plan is to use an LED panel behind it.
  7. maverick75
  8. CaptainComet
    Wow, those do look good. They play down the big bumper, too. Brings a much better scale between all the parts involved. They should have followed through on this. :thumbs2:
    Probably didn't because they were pushing the Granada and wanted to phase out the Mavs. Give it new styling and that may have prolonged the process.
  9. wjtkb
    wjtkb Member
    keystone heights fl
    maverick, 94 toyota pick-up, 94 honda accord
  10. maverick75
  11. zorares
    zorares Member
    Midlothian, Texas
    1973 Ford Maverick
    Now this is an interesting rear end. Brazilian I believe.
  12. Mavaholic
    I built this tail light. This picture was done on the computer but I have the actual lens and bezel made and mounted on a modified tail light panel.
  13. John Holden
    John Holden Member
    NJ
    Mavoholic, that is killer!
  14. Douglas Ribeiro
    Douglas Ribeiro Member
    Brazil
    Maverick Weber 347
    Hello all right! I want your help, I liked this model lanterns, of which car?
    Thanks,
    Douglas
  15. jncastell
    jncastell Member
    Ogden, Utah
    1974 Maverick Grabber Clone
    (y)B after the the Brazilian ones.
