What weight engine oil for a 302?
Discussion in 'General Maverick/Comet' started by mrcomet, May 10, 2009.
  1. Shinysideup
    Shinysideup Chillin the most
    town
    car
    All 5W is part synthetic. Read the LABEL.
  2. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    I've been running synthetic in my 200 I6 and it doesn't leak or burn oil, no more than 1 quart between changes at around 5,000 miles.
    I think it just depends on the engine and not the fact that it was synthetic oil. I mean they also make synthetic specifically for high mileage engines so why would they make a synthetic oil that is going to cause your motor to leak all over the place?
  3. DaMadman
    Southern MD
    Not really very accurate
    Another way of looking at multi-vis oils is to think of a 20W-50 as a 20 weight oil that will not thin more than a 50 weight would when hot.
    or to think of it REALLY simple 5W-30 is approx. 30 weight when cold and thins down to 5 weight when hot. that is really just an easy way of looking at it and NOT a true weight to heat ratio.
  4. brainsboy
    brainsboy Member
    Tampa
    I used to work for an oil company years ago 10W30 and 20W50 are your best two choices
    IMO stay away from 5w30 10w40. The problem is that as the amount between high and low number increases, in order for the oil to reach these numbers they increase the amount of polymers in the oil. Which is a main cause of oil breaking down faster. Does this mean you cant use 10w40 not at all, I just feel oil has better protection with less polymer filler in it. Either way if you change your oil more often you will be fine.
  5. Acornridgeman
    Wisconsin
    I'm not accurate ? ..... :16suspect
    I beg to differ. You are 100% backwards ... the W in an oils viscosity rating refers to what the oil performs (flows) like at 0 degrees F --- in this case 5W is the cold rating
    The 30 is the rating at 212 degrees F
    Look it up if you don't believe me.
    Here is a quote from a tech article:
    The SAE has established two temperatures by which to base oil weight. 0 degrees Fahrenheit is used as the low-temperature baseline while 210 degrees Fahrenheit is used as the high-temperature baseline. Oils which adhere to the cold-temperature SAE requirements will have the letter “W,” meaning winter, after the viscosity rating (e.g. 5W, 10W, etc.). Oils meeting the SAE high-temperature requirements will have no letter next to the weight, as in the SAE 30 example above.
    From this explanation, we can now gather some understanding about a bottle of oil by looking at the numbers. Using 10W-30 as an example, we can determine that at an oil temperature of 0 degrees Fahrenheit, the oil has the properties of 10 weight motor oil while at an oil temperature of 210 degrees Fahrenheit, the oil has the properties of 30 weight motor oil. This multi-viscosity behavior is achieved through the use of a viscosity modifier additive in the oil. The additive is dormant at cold temperatures but as the oil warms up, the modifier produces a thickening effect.
  6. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    10w 40 or 10-30 is a good viclosity to run..but of course weight vary depending on youre climate area
  7. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    on a side note...flat tappet cams need phosphurous and zinc
    so either find a zinc based oil(they just brought this back several months ago...sl rating?)
    or go get some zddplus additive!
  8. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    While I don't have the technical knowledge to dispute what you say, that sounds backwards. If that is true why would say a 10w-40 oil flow thinner out of a warm engine then from the bottle? You could pour it in, warm the motor and drain it and it will flow much thinner from the pan then it did from the bottle, or even flow from the bottle much thinner on a warm day then in the winter.
    I have heard what you said before but I can't wrap my mind around that fact.
  9. Acornridgeman
    Wisconsin
    I see what you are saying, but it is not as simple as to how fast it flows from the bottle or out of a crankcase hot or cold.
    this is from Mobile oil
    Question: Explaining Viscosity DesignationsWhat does 10W-40, 5W-30 etc., mean? I would really appreciate it if you could explain it in simple language so I can teach my students. There are so many different grades of oils. Which one is better to use in summer then winter (Chicago) and vise versa? Thanks a lot. -- Vijay Patel, Lake Zurich, IL
    [​IMG]Answer: In simple language, the first part of the viscosity designation (W grade) is an indication of the product's ability to help an engine crank and start and for the engine to pump the lubricant. The lower the number (0W is the lowest), the lower the temperature the product can be used. So the W grade is related to the lowest temperature your engine sees when you start the engine on the coldest morning of the year. But also keep in mind that a lower W grade pumps and helps an engine to start better than a higher W grade. The second part the viscosity grade is related to the viscosity your engine sees at operating temperature. In this case, a higher number is a higher viscosity grade and provides more viscous oil at operating temperature than lower viscosity grade oil. It is not safe to assume that a higher viscosity oil is always better for your engine because other factors, such as engine design, fuel economy and power, are also related to operating viscosity. You should always consult your owner's manual for the right oil to use for your particular engine. For more information on the viscosity grade specifications, a quick search of the Internet will identify several Web sites where information about SAE J300 (Viscosity Properties Test) can be found.
  10. DaMadman
    Southern MD
    #1 I did look it up and the numbers that are being used such as 5 10 20 30 40 50 are all arbitrary number that SAE Made up in the first place... Don't believe me look it up..,.. Here is the tech article
    The weights given on oils are arbitrary numbers assigned by the S.A.E. (Society of Automotive Engineers). These numbers correspond to "real" viscosity, as measured by several accepted techniques. These measurements are taken at specific temperatures. Oils that fall into a certain range are designated 5, 10, 20, 30, 40, 50 by the S.A.E. The W means the oil meets specifications for viscosity at various low temperatures depending on weight, and is therefore suitable for Winter use. 5W is tested at -25C, 10W at -20C, 15W at -15C, and 20W at -10C.
    #2 if what you are saying is true and 5W is how oil flows at 0 degrees and 30 is how it flows at 212 then you are saying point blank that 5 weight oil is thicker than 30 because everyone knows that oil is thicker when it is cold than when it is hot.
    With that said to disprove your theory why is 90 weight gear oil thicker than any motor oil like even straight 30 weight???
    The example that I gave in my other post was meerly trying to give something in laymen's term to make it easier to understand and without going into all the testing and and additives crap that oil goes through to get rated at a certain viscosity by SAE
    The way it work is just as above with 5W being tested at -25 and 10W being tested at -20 and so on. They take an oil and lover the temp down to -25 degrees and make it flow at a certain viscosity by adding thing to it and then when it warms up to normal temp it thins out and that is what we call 5W - ?? then they heat it up and add stuff to it until at a certain temp it won't break down and flow any faster than 30 and with all those things added and the hot and cold you get 5W-30 then they take oil and drop the temp to -20 degrees and add stuff until it flows at that same viscosity and when it warms up you had oil that we call 10W you get the picture.
    But in laymens terms 10W -30 is the same thickness or same viscocity when hot as 10W - 40 (it is 10W) but 10W - 40 is thicker when it is cold then 10W30 because 10W 40 is 40 "weight" when it is cold and 10W30 is only 30 "weight"
    The higher the 2nd number the thicker the oil is when it is cold outside.
    at 32 degrees 10W30 is thinner then 10W40 and 10W40 is thinner then 20W50 and straight 90W gear oil at the same temp is thicker then all of them
  11. Acornridgeman
    Wisconsin
    I see what you are saying. They start with 5W and add addatives to make it thicker at 212F to act like a straight 30 weight.
    But - you keep talking like what I wrote is wrong. What I printed comes straight from Mobile Oil ........... :yup: ......... are you saying they are wrong?
    10W30 and 10W40 will test the same at 0 degrees F - they are 10W oils - the thickness pouring from a bottle doesn't matter - the testing does.
    5W30 and 10W30 will test the same at 212 degrees F - they are both 30 weight oils.
  12. Fish OutOfWater
    Fish OutOfWater Brian
    Long Island, NY
    We can all agree that a 30 weight oil is thicker at zero degrees than it is at 210 degrees.Let's say it is the right weight at 210 degrees, but you its zero degrees outside and 30 weight oil is way to thick to lubricate properly. Well, 10 weight oil would be thin enough at zero degrees, but it would be too thin at 210 degrees. So the manufacturer adds modifier to 10 weight oil to give it the lubricating properties of a 30 weight oil at 210 degrees, and return to 10 weight oil properties at 0 degrees.
    Does this mean the oil is getting thicker as it warms up? Of course not! Think about it. 10 weight oil at zero degrees will be thicker than 30 weight oil at 210 degrees. 10W-30 just means it's 10 weight oil that has the viscosity of 30 weight oil when it reaches operating temperature. Does that make sense to anyone? Dont take this as gospel, its confusing and I am not sure I even know if what I am saying is 100% correct. Just my interpretation of what I have read.
  13. Jamie Miles
    Alto, GA
    I've had a few
    :hmmm: :banghead:
  14. Fish OutOfWater
    Long Island, NY
    Again, its not that 5 is the viscosity at 0 degrees and 30 is the viscosity 212 degrees as you are implying. The viscosity of 30 weight oil at 210 degrees is going to be lower than the viscosity of 5 weight oil at 0 degrees. You are comparing apples and oranges. Again, 30 weight oil is still 30 weight, weather its 0 degrees or 210 degrees. However the viscosity will change as the 30 weight oil heats or cools.
    I like it when you put it in laymens terms so that I can understand it, but this statement is a train wreck. Sorry I gotta go with Acornridgeman on that.:rolleyes:
  15. Fish OutOfWater
    Long Island, NY
    You are right about that. It is a thinner 20 weight oil when cold but at operating temps the viscosity modifier thickens the oil so that it will not be thinner than a 50 weight oil would be (at the higher running temperature of 210 degrees)
    I figured I didnt get it 100% correct in my earlier post. I said:
    Should have said (and changed it to): So the manufacturer adds modifier to 10 weight oil to give it the lubricating properties of a 30 weight oil at 210 degrees, and return to 10 weight oil properties at 0 degrees.
    Acornrideman's tech article quote summed it up nicely:
    Sorry for the confusion.
