I am going to a local shop in Shingle Springs. I have heard a lot of good about the place. They are probably about a half hour away from you. I will definitely let you know how it works out. Thanks everybody for all the information.:Handshake
You could go check out some junkyards and look for an 80s-90s Aerostar. They will have an aluminum drivsahft with the correct yoke also. The both the 2wd and AWD aerostar shafts will need to be shortened to fit a Mav with a 9 inch. Around here I pick up these shafts for $30 at the yards. then you said $70 or so to shorten it. Youd have an aluminum shaft in the car for about $100.
