What's this on my oil drain plug....
Discussion in 'Technical' started by mashori, Jun 29, 2012.
  1. 71gold
    ...ever seen one fail...:huh:
  2. mav1970
    Chinese - quality - control
    3 words that have never been put together in a sentence before :D
  3. 71gold
  4. pegleg1858
    pegleg1858 Member
    kentucky
    69 1/2 maverick
    I wouldn't be scared to install another. But if you dont, a road draft tube is also an option. PCV valve always seemed to be the best option due to the fact that your sucking the vapors out of the engine. A lot of that vapor is stuff that will dirty your oil. If you dont believe it, pull a pcv valve apart that is off a newer engine that still has clean oil in it. They are nasty.
  5. Resto
    Resto Benders Evil Twin
    Yuma AZ
    Nope..Id get an acumulator that feeds the oil spray into a small tank with venting.
  6. Streamliner
    Streamliner Member
    This......I have a -12 an hose from each valve cover going to a vented can.
  7. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    So I checked out the PCV and looks to be intact, nothing from my Carb, and I took apart a spare lifter I had laying around and nothing similar inside it.....
  8. yellow75
    Tillamook Oregon
    Well I guess the mystery continues then, was easy enough to check to see if it was a pcv valve component though.
    Hopefully you will figure it out, may have just been something that fell in somehow in one of your tear downs and not even related to your engine :hmmm:
  9. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    yea I kinda agree with you on that...
    I'm gonna get a magnet and place it on the outside of the oil pan just in case...
    beyond that just wait and see what happens...
  10. Dave B
    Do you keep your hood locked when the car is outside overnight?
  11. mav1970
    Could they perhaps be parts from a previous PCV valve?
  12. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    no...but the people in my neighborhood aren't the type to mess with my car...and if they were they wouldn't have a clue how to get under their own hood, much less mine...
    but I did give that concept a thought....
    to put a checkball in there would be stupid, it's too round, less likely to get stuck somewhere vital or get between bearing surfaces....
    to put a checkball AND a spring in there is just weird....
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I had this one on the older engine as well . . .
    haven't had a different PCV valve than this one.
  14. Bryant
    maybe it was parts from the ball point pen you were missing after that one time you were working on your motor.
