What's wrong with this ???
Discussion in 'Technical' started by boss9, Mar 26, 2006.
  1. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    Thought about drilling new holes. But that changes the position of the tranny as well. I'm already going to have a tight fit with the 69.5 tunnel. Maverickgrabber, I compared the mounts with Inline6's when I got them. They measured up the same. Next step is to move mounts around and try it again.
  2. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I thought that looked wrong too, but it really does work. :)
  3. Mavaholic
    No because the frame mount surface is at an angle. The engine mount and frame mount surfaces are supposed to sit flat against each other. You can easily slide the bolt in & out when they are sitting the way they are supposed to be. Drilling a hole higher up will also space them further apart. If you had enough material to raise the motor and drill holes through the frame and engine mounts, the weight and pressures would fall on the bolts with a perfect shear plane at each end.
  4. ronr11
    ronr11 Member
    hartsville sc
    71 maverick
    had this problem when putting my 302 in the engine mounts were boxed wrong
  5. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    :dance: Engine is in !!!!!:dance:
    :mad: !#@&%*&^%$#! SWAYBAR !!!:mad: Harmonic balancer was hitting swaybar. Also the frame mounts were backwards. Now if someone could look at the engine heighth. Look at the pics of the location of the exhaust ports in relation to the shock tower notches, does this look right ???
  6. inline6
    inline6 Member
    lookin goooood!!!(y)
  7. Grabber5.0
    Kansas City, MO
    71 Grabber
    Looks alot better. Question: Should there be paint on the gasket surface of the exhaust ports? :confused:
  8. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    I did cut more out than most notched towers I've seen. In fact I had to grind on the a-arms a little. Now to figure out headers !! What are you using for exhaust scrapper60 ? I may just use stock 302 manifolds.
  9. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    looks right to me
  10. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    MaverickGrabber, do you know the part number for the Hedman headers that fit the 351w in a Maverick ? Trying to figure out exhaust now. One hurdle at a time !!!
  11. Jamie Miles
    Alto, GA
    I've had a few
    All that awesomeness and your going to ruin it with stock manifolds? Come on now... :p
  12. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    Jamie, I know the stock manifolds will choke it but, depending on the cost of headers I would rather drive it with stock manifolds than just look at sitting in the garage !!! Unless you could swing my daughter's college tuition or my son's driving school fees!!:biglaugh::rofl2:
