Wheel adapters
Discussion in 'Wheels and Tires' started by awannabegrabber, Jun 27, 2006.
  1. Mavaholic
    If you draw a circle through the center of the studs, the diameter of the circle will be 4 1/2 inches.
  2. Craig Selvey
    Don't use adaptors...not worth it IMO
  3. awannabegrabber
    awannabegrabber Always Learning
    Wichita, Kansas
    1976 Maverick with a trim package
    OK. Thanks for your help
  4. 1972Grabber
    1972Grabber Always Broke
    SAN ANTONIO, TEXAS
    1972 Maverick Grabber
    Here is Tim measuring bolt spacing: http://pics.bothner.com/2005/NCDec/NCDec083.html
    :biglaugh: :rofl2: :biglaugh: :rofl2:
    Or you could do it this way which is the preferred method.
    http://www.rsracing.com/tech-wheel.html
    Notice that on the 5 lug wheel, that you measure from the CENTER of one bolt hole across to the OUTER EDGE of the other bolt (or hole) as necessary. Look at the pics real close and you will see what I am talking about.
    This link will also tell you everything you need to know about critical rim measurements.
  5. awannabegrabber
    Wichita, Kansas
    Nice. Measuring bolts. Good stuff
