wheel tire question
Discussion in 'Technical' started by ptpdub, Jun 4, 2024.
  1. ptpdub
    ptpdub Member
    canada Sk.
    If I have a 14-inch wheel that measures 7.5 inches across, how do I determine the size of tire I should be looking to buy? image0.jpeg
  2. 71gold
    Try to go no more section width than the rim width...JMO
  3. dyent
    dyent Member
    vancouver bc
    There used to be a couple of great tire/rim calculator sites, but no longer working, see if this helps........if not, just do a google search..........
    https://www.wheel-size.com/calc/
    David
  4. TeeEl
    TeeEl Senior Member
    Colorado
    It depends pn the aspect ratio of the tire. For example: a 45 series tire requires a wider rim width than the same size tire in a 60 series...
  5. krelboyne
    krelboyne Remember
    Salem, Oregon
    Wheel widths are measured on the inside beads.
    TeeEl and Krazy Comet like this.
  6. Krazy Comet
    Yup, that's 6" bead to bead.
