When to shift with T5?
Discussion in 'Drag Racing' started by mashori, Jun 3, 2010.
  1. mercgt73
    here's a neat MPH/gear calculator: http://www.f-body.org/gears/ you can do side by side comparisons of changes.
    it can also help you see where your RPMs will be after your shifts, to help match them up to your dyno sheet.
  2. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I use 5th on the freeway a lot . . . I'm at 2200 in 5th going 75mph.
  3. 302-72-mav
    302-72-mav Member
    sactown CA
    yah going 80 in 5th gear would drop the rpm's way lower than yours
    is a world class t5 gearing longer than the normal one's
  4. 302-72-mav
    302-72-mav Member
    sactown CA
    i think this is my gear ratio
    what is yours
    89-92 V8 T5 (World Class)
    Borg Warner T5 WC
    Gear Ratios : 2.95, 1.94, 1.34, 1.00, .62
    Spline : 26 input/27 output
    Dimensions :
    Torque Rating : 305 lb-ft
    and this is what the link toled me and it seems right
    with the 3.25 ratio
    it goes ----- 1 gear 2 gear 3 gear 4 gear 5 gear MPH
    at 3000rpm it is--28 --42-- 61-- 82-- 133
    at 5000 rpm it is--47 -- 71 -- 102 -- 137 -- 221
    and with 389's it's
    at 3000 rpm is --23 --35 --51 --69 --111
    at 5000 rpm it is--39 -- 59-- 86 --115 --185
