Where does (can) electric Choke Connect?
Discussion in 'General Maverick/Comet' started by gregmaverick, May 8, 2015.
  1. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    I replaced the stock Carter YF carburetor with a Weber. The Weber has a an electric choke, the Carter had a "choke stove".
    I seem to recall that I saw somewhere that the electric chokes on some Fords connected to one of the wires on the alternator.
    I do have the ability to run a wire across the engine compartment to the relays that I wired in for the electronic ignition & electric fuel pump, but I was hoping to keep the wiring simple and neat.
    Any information? Thanks!
  2. tody
    tody Member
    cologne, germany
    STA connector on the alternator.
  3. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    Thank-you very much! :clap:
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Does that provide voltage only when the engine is running?
  5. Krazy Comet
    Dismal Swamp
    littlekentucky likes this.
  6. tody
    tody Member
    cologne, germany
    yes, and it's also variable in voltage depending on engine rpm. so the choke opens slower in the city and quicker on the highway...
