I was just walking thru the garage and I heard a drip. I just happened to walk at that specific time to here it and see less than 5 drips on the ground. :-( Where is it coming from? Am I correct that is the bell housing for the tranny, but hows does Antifreeze get into it?
look at your Freeze Plugs for a Seep. look at the Head gasket for one also. leaks will run horizontally across Oil Pan Rails ,and across Intake Manifolds. Check water pump weep hole!
could be if coming "out"of the bell housing... but as mentioned, the bell housing is the lowest point so it could be coming from anywhere on the motor.
I had a 289 Engine that was cracked from a Freeze , the Crack was on the back of the Block . The 1 inch long Crack would only leak some times!
71gold: No puke bottle, just the tube off the radiator cap E. Raider: No chance of freezing, was inside (heated) all winter Rasit:
Some excellent stop leaks on the market that would be a short term fix for that. Also good old sodium silicate(liquid glass) to fix very large cracks in just about anything.
