Where to shop for digital dash
Discussion in 'Technical' started by 007GT, May 16, 2017.
  1. 007GT
    007GT Member
    HOUSTON
    74 MERCURY
    I want a digital dash for my 007gt comet.
  2. 71gold
    rthomas771 likes this.
  3. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    Very nice, Those look great.
  4. 007GT
    007GT Member
    HOUSTON
    74 MERCURY
  5. Jerry
    Jerry Member
    Woodstock, GA
    77 Maverick 2dr 302, 74 LDO
    Has anyone done a write-up on how to install aftermarket gauges like these?
  6. rthomas771
    I didn't cut the cluster plug off...I spliced the wires so I can undo if later down the road I wanted to go back to factory cluster.
  7. 71gold
    I cut the plug off then ran the wires to the control box. another good thing about these gauges...no speedo cable, just a wire running down to the transmission...:thumbs2:
  8. yellow75
    Tillamook Oregon
    I assume that they work off of the dimmer switch as well for brightness, they sure look right at home in the cluster
  9. 71gold
    it has it's own dimmer switch on the control box...the light switch is not in play with these gauges. the stock wiring in the car, it's like it was wired for digital gauges from the factory.
    other functions I like...:drive:...:chirp:
    Performance Meters
    ·0- 60 MPH Timer (0- 100 kmh)
    ·1/4 mile time
    ·1/4 mile end speed (trap speed)
    ·High speed recall
    ·High RPM recall
    they reset automatically on each restart of the car.
  10. 71gold
    all of this takes longer to say/read than to do...
    I used an old cluster.
    pic #1...old cluster bezel.
    pic #2...cleaned and sanded.
    pic #3...painted in silver.
    pic #4...pinstriped edge.
    pic #5...painted (rustoleum 7777 satin black) w/pinstripe removed.
    pic #6... done.
  11. 71gold
    Jeff and Collin have a new cluster lens in theirs. I took the option for the old hazed lens and cut out the openings you need the lens, it's like a spacer when reassembling the cluster.
    pic #1...parts to be used from old cluster.
    pic #2...old lens.
    pic #3...prepped to mark for cutting out.
    pic #4...marked for cutout.
    pic #5...lens openings cut out with scroll saw.
  12. 71gold
    post 10/11 are just prepping the cluster for looks.
    after gutting the cluster of all it's bulbs, gauges and printed circuit ...
    the light bulb shields need to be removed.
    ...that's all the mods for the cluster housing...:thumbs2:
  13. yellow75
    Tillamook Oregon
    Thanks Frank for the info and pics I have been saving a cluster just for digital gauges one day and after seeing yours (and Jeff's and Collin's) there is no doubt in my mind as to what ones to get.
  14. 71gold
    notice I didn't post anything about the wiring of the control box....
    the gauges plug into the box and the wiring from the stock cluster plug is simple.
    pic below...(view in original location)
    the only wires not hooked up are the turn signals and reverse lights...:yup:
    I have installed two sets of these gauges so that means anyone can do it...LOL
  15. Jerry
    Jerry Member
    Woodstock, GA
    Very informative pictures and it turned out great. Do you have any pics showing how the gauges were actually mounted to the plastic housing?
