Which exhaust manifolds for 5.0 HO/T5 combo?
Discussion in 'Parts Interchange' started by 72redux, Dec 5, 2017.
  1. 72redux
    72redux Member
    tacoma, wa
    1972 maverick 2 door
    I'm in Tacoma.
  2. 72redux
    72redux Member
    tacoma, wa
    Interesting, The Comet/Mav manifolds just kind of head for the firewall at a real lazy down angle. That's not what I would've thought at all. There's not very much room at all on the drivers side to get down past all the steering gear before you hit the firewall. I was almost certain the stock pieces would've been looking down at a pretty good angle. I doesn't really make a difference, as long as everything fits and works. They certainly need a good sandblasting. Should I have a machine shop resurface the gasket area to check for and/or take out any warping, or do you just blast em and slap em on?
  3. Krazy Comet
    I don't remember configuration of pipe on Comet... Apparently was "S" bend on each side, whereas Stang, Fairlane, Falcon, etc used a 45*-ish angle on driver's side and S on passenger... That could have been for ease of assembly on assembly line...
  4. baddad457
    I would look into Tri-Y's if they'll fit a Mav. Use soft copper gaskets and fully compress em tightening and they'll out last your brother. I have Hedman 4 into 1's on mine with NO clearance issues underneath aside from the shock tower clearance (shaved mine off the bat)
  5. maverick600
    maverick600 Member
    San Angelo, Texas
    Was there any results noted for this?? I know it's over 1.5 yrs old but cutious.
  6. 72redux
    72redux Member
    tacoma, wa
    I went through A TON of hassle to hunt down 351 windsor manifolds from late 80''s early 90''s fuel injected ford pickups. They have a 2 1/2" downpipe so I figured more flow, but after all the hassle, they didn't fit. They hit the shock towers.
    I ended up having to use hedman shortys. I haven't actually bolted them up yet, but I have heard more than a couple guys complan that they come too close, or interfere with the idler arm on the passenger side.
    I expect to fit them up soon, and I'll post as soon as see how it goes.
    BBMS18 likes this.
  7. Earl Branham
    Lugoff, SC
    I have a set I would be willing to let go of. I do have a T5, and I know they work. Where are you located?
  8. mojo
    I have Hedman's on my 302, they don't interfer w/ the IDLER arm; the problem is w/ PITTMAN arm. I have not heard anyone state, issues w/ IDLER arm...
