Which One Is Best?
Discussion in 'Technical' started by coutangman, Dec 17, 2007.
  1. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Damn, that looks downright sexy in there.
    It could also be the tequila I'm drinkin, but damn.....
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I thought that one could have been excuted a little cleaner.
    If you think that one is sexy, you'll love these!
    You'll notice that not all are in Mavericks, some are in 65 Stangs.
    I have saved those pics too though because the engine bays are the same width tower to tower AND those Stangs use the same headers for the swap as a Mav. So to see a C in a 65 Stang is pretty much identical to looking at one in a Mav.
  3. ratio411
    ratio411 Member
    Pensacola
    More pics.
    One or two are B302s... Look amost just like a C in there.
  4. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Drool....:bowdown:
    Makes me want to put a 351 in mine, but I have almost everything for my 302 now. And i just got headers for the 302.
  5. ratio411
    ratio411 Member
    Pensacola
    Hey Jim,
    Did you ever find out what years and types of 351s are available?
    Just curious...
    IMO the earlier engines are best... 69-73 for the W, or 70 for the C.
  6. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    This has to be one of my all time favorite Mav's.
    [​IMG][​IMG]
  7. baddad457
    The Cleveland exhaust face on the heads is at a 45* angle to the ground. The 302/351W is nearly vertical to the ground. The hard part about the bolts on a Cleveland exhaust is you almost have to access all from under the car, unless you shave the towers. I consider that a must with any of the three. It was the first thing I did on mine after I pulled the 302 out. And after installing the 331 and the headers, it was the best investment I made in this car.
  8. coutangman
    coutangman Member
    Charlotte, NC
    Thanks for all the great info. I did not realize that you could not have a 4 speed behind the 351, and only a floor shift automatic.
    I had planned on installing a toploader behind the 351, so I guess it's back to finding a 302 for the car. I am also not crazy about cutting the shock towers. Too traditional, I guess.
    I am not planning on racing, anyway, so I guess a 302 would make more sense for my application. A 351 would have been eye candy, anyway.
    Again, thanks for the advice.
    Jim
  9. Jamie Miles
    Alto, GA
    I've had a few
    That's a '69.5.. Awesome car!
  10. maverickdvm
    maverickdvm Member
    Michigan
    I like 72 for my Clevelands, good thick walls for boring.
  11. baddad457
    There's no reason you cannot use a manual trans behind a Cleveland in a Maverick. I think you misunderstood ratio411's post. He said it wasn't possible with the stock manifolds. Nothing said there about headers and a 4 speed. If it can be done in a 65-66 Stang or any other shock tower equpped Ford/Merc, it can be done in a Maverick. Some day when I'm done with my V8 Ranger, the Toploader 4 speed in it, will find a new home in my 77 Comet. I've no doubt it'll fit behind the 331 and with the Hedman long tube headers. Ditto for a Cleveland in front of it too.
  12. ratio411
    ratio411 Member
    Pensacola
    Yeah, I meant that a manual tranny wouldn't fit with the stock manifolds.
    This is assuming that you would use the stock clutch linkage too.
    If you went with a cable clutch, or hydraulic set up, you could use the manual tranny.
    The problem with the stock manifolds on a Cleveland is the driver side exit is right at the Maverick Z-bar. I suppose the Fords that came with Clevelands had more room so the equalizer wasn't cramped. Our equalizer bar is a tight fit from day one.
    That said, there are more than one style of manifold.
    There might be one out there that works and I just never had it to try.
    The ones I had all exited the same on that side.
    The passenger sides are very different though, from model to model.
    I think I ended up using a 70 Stang passenger side... or was it a Torino:huh:
  13. ratio411
    ratio411 Member
    Pensacola
    Where did you find this out?
    I have always gone for the 70s because of the higher nodularity and they were supposed to be the thickest.:huh:
    I know the nodularity is true, but the thickness part was heresay.
    I also know that the non-Boss 4 bolt main 351s, aka Cobra Jet, were the thinnest. I read an old Super Ford article where they sonic tested every Cleveland in sight and the CJs were all paper thin.
    IIRC, the article said to pick up a Boss block (I guess they were on every corner then) or get a 70 block and convert to 4 bolt.
  14. maverickdvm
    maverickdvm Member
    Michigan
    I have my blocks sonic checked, my bored .030 to .040 over 72 blocks have been thicker than stock blocks after boring.
  15. baddad457
    In that case, anyone want a 72 Cleveland ?????? I got one to sell.........................std bore--std crank..................never been apart since it left Ford................
