Which one of these holes should I use for oil dipstick tube?
Discussion in 'Technical' started by scooper77515, Mar 5, 2014.
  1. baddad457
    Didn't know you'd modded the car. You need the stick to go into the rear sump. The front is simply a "room" to house the oilpump, the oil over flows it into the rear in operation, it's not actually a sump per se.
  2. scooper77515
    Yep. Cut out the towers and put in a Rod and Custom power rack and pinion setup.
  3. 71gold
    my Lokar stick had a set screw to move the stick in/out of the handle for calibration.
    the pan I have now is a modded 6 qrt. stock pan. after the mod (for crossmember clearance) the stick still read full with 5 qrts in it. I then added a remote 1 qrt. oil reserve to return it to 6 qrts. it's located behind the driver side headlight in the wheelwell.
