Who's runnin injection?
Discussion in 'Technical' started by mavtricks71, Sep 23, 2008.
  1. gwil81
    gwil81 Member
    oakland,ca
    1977 maverick
    How did u fit it. Would that work for a 77. My sending unit on Bottom driver side. Not at the top
  2. 71gold
    it's the late model (77) maverick tank...Spectra F30). I had a 66 mustang sending unit, same as Maverick in it so it was a direct swap.
  3. gwil81
    gwil81 Member
    oakland,ca
    1977 maverick
    Are you telling that the Holley fuel pump fits in our Maverick on the bottom driver side? Do you have any pictures
  4. 71gold
    yes it does. it looks and fits just like the stock sending unit, just has 4 wires coming out...2 for stock fuel gauge and 2 for E-fuel pump.
    I'll get a pic. tomorrow.
    I flew out of Oakland Ca. to Viet Nam in the mid 60s.
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    How does it do at low fuel levels? Curious how their Hydramat actually works.
  6. 71gold
    I'll know today, I have a quarter tank of gas (5 gals) to check it out.
    RMiller likes this.
  7. gwil81
    gwil81 Member
    oakland,ca
    1977 maverick
    Please keep me posted
  8. 71gold
    everything seems to be doing great...:thumbs2:
    here is the installed pic.
    RMiller likes this.
  9. gwil81
    gwil81 Member
    oakland,ca
    1977 maverick
    Is it facing the trunk? How is it doing with the fuel gauge? Also how are your filters mounted?
  10. 71gold
    it's in the same place the stock maverick sending unit was...driver side of tank.
    it comes with 3 different float arms, just put on the one for the size tank you have.
    second filter is under the hood just before the fuel rails,
  11. dyent
    dyent Member
    vancouver bc
    Hi Frank:
    You mentioned a 66 Mustang sending unit is same as our Mav/Comet units? So bolted up to our fuel tank OK? If that is the case, then I wonder if this would work?
    https://www.ebay.com/itm/64-68-Must...261033?hash=item51cbd7afa9:g:mpAAAOSw-yxU27rT
    David
  12. gwil81
    gwil81 Member
    oakland,ca
    1977 maverick
    I'm on hold with summit racing right now. Are u running the sniper system? If so how long did it take to insatll
  13. gwil81
    gwil81 Member
    oakland,ca
    1977 maverick
    I had order this one yesterday. Before hear about the in tank.
    Check this out at Amazon.com
    Spectra Premium FG178B Sending Unit https://www.amazon.com/dp/B006P8SIR8/ref=cm_sw_r_other_apa_i_kyUVEbNXSDWBY
  14. dyent
    dyent Member
    vancouver bc
    I think that would work better, has 2 pin connector (like on Mav/Comet) on the FG178B, the one on eBay looks like it only has 1 pin connector.........and its cost less too!
    David
  15. 71gold
    from post #30...Pro Flow 4 multiport injection
